Zoneminder and fridgate
jeremyoha450
Hi guys
been trying to find Zoneminder or Frigate in the apps of truecharts and none of them show up
is there instructions somewhere on how to install them on scale?
regards
Jeremy
morganL
Captain Morgan
Administrator
Hi guys
regards
Jeremy
Zoneminder is a docker container.... with some idiosyncrasies
It's in the incubator train
Ppriorfl
Did you ever get frigate installed? I'm trying and getting errors in the logs.
vikonen
Actually succeeded in getting the chart to work, and the PCI coral too.
Just wondering if you figured out a way to map a local (hostpath) folder to the app's /config?
It would be easier to troubleshoot the config.yml with a file editor rather than the chart edit UI checkboxes.
