Hello everybody
My brother is starting his new job in the medical field, so i built him a nas using truenas. Awesome.
For radiography images AND database they use a software called vixwin.
Assuming this can be stored in a dataset:
Is it advisable to turn on write sync?
Is it advisable to turn off compression?
For the database part should these options be the safest to prevent database corruption? On the other hand, could the massive x-ray images benefit a lot from compression, since they are be uncompressed, thus saving a lot of space?
What would you suggest?
It could also be possible to make a dataset for database and a separate dataset for images, and then link them together using hard links, but that sound like complicating things further.
Thank you :)
Thank you :)
