Yes or No to upgrade from repository?
Louis2
From the Linux command line you can update and upgrade to the latest repository versions:
# apt update
# apt upgrade
However there are as far as I know no public nightly builds.
My questions are:
- is it relatively save to upgrade this way?
- is it possible to return to the formal version if something went wrong?
- will it be possible to upgrade to the next formal release?
Louis
Patrick M. Hausen
It is not and please don't. TrueNAS SCALE is an appliance just like TrueNAS CORE and the only supported way to upgrade are the official releases.
anodos
Sambassador
Louis2
Thanx, will try them. At this moment the truenas instance I am working on, is just for testing, so I can take some risk.
Louis
