WireGuard and PIA
ZodiacUHD
Hello everyone,
I was wondering if anyone had success setting up a jail running transmission and connectin to PIA VPN using WG instead of OpenVPN.
I'd like to switch to this solution but i don not have the knowledge to do it on my own: i can follow a guide for openvpn and understand what is going on but i wouldn't be able to start one from scratch.
If anyone would be so kind to help, i'd be very glad,
Cheers
ZodiacUHD
I've already stumbled upon that post, unfortunately i get kinda lost after the basic installation of what is required. I'll keep researching trying to understand it.
ZodiacUHD
Hey Dan,
PIA stands for Private Internet Access and it's a VPN that lets you mask your IP as if you were connecting from somewhere else, particularly useful with Transmission.
cheers
Dan Tudora
hello
I joke with VPN question
but what for ??
try PopcornTime for movies if you want !!
success
ZodiacUHD
I'm well aware of popcorntime, it's just not something that fits my usecase. Thanks anyway for the suggestion ;)
Patrick M. Hausen
I have a droplet at Digital Ocean with a WireGuard endpoint in the US. 6€/month.
ZodiacUHD
Hey there Patrick,
thanks for the reply. As afr as i'm aware they are officialy supporting WG now. i'll keep digging ;)
Patrick M. Hausen
If they do support WireGuard they should have documentation available for that specific use case. But none of us has got a crystal ball and tonight was the very first time I heard of PIA ...
Dan Tudora
well, well
if your particular case need some help, call provider !!
of VPN of course
cheers
Patrick M. Hausen
Dan Tudora
@ZodiacUHD Seems like you are right about WireGuard support on PIA's side. Possibly this is helpful:
is toooooo much for that situation
user need some help in their usercase/situation
DO NOT tell to read another documentation from another site/vendor
IF you have a solution for their "weird" need provided solution
user can't use OpenPfsense as solution
cheers
Patrick M. Hausen
This is a description how to set up WireGuard on OPNsense to connect to PIA. OPNsense is FreeBSD and WireGuard is WireGuard, so all the essential things should be adaptable. I do not recommend installing OPNsense ...
I don't have a solution. I don't use PIA - how should I have one? Here's one guy who documented how to do this on another FreeBSD based product. The OP should at least check that resource.
Dan Tudora
I USE Pfsense and 1 OpenSense
for me OpenSense make tooooo many update/change for a mature/stable firewall
for the OP you MUST define your need
IF you need some special "need" use PM
cheers everyone
going to sleep
alwu
goerz
Hello everyone,
Cheers
I managed to use wireguard for my PIA VPN connection. Also, I managed to have wireguard connect automatically at startup, opening a port and forwarding it to transmission.
I started from the scripts found here:
I put all these scripts in /PIA in my jail. I changed most of the references from relative to absolute paths. In run_setup.sh I specified the location of a file with my VPN credentials, and I set the connection mode to wireguard:
PIA_AUTOCONNECT="wireguard"
I also fixed a small error in connect_to_wireguard_with_token.sh that prevented port forwarding: the variables PF_GATEWAY and PF_HOSTNAME must exported in order to be used by the port_forwarding.sh script.
PIA_TOKEN=$PIA_TOKEN \
  PF_GATEWAY="$(echo "$wireguard_json" | jq -r '.server_vip')" \
export PF_GATEWAY
  PF_HOSTNAME="$WG_HOSTNAME" \
export PF_HOSTNAME
Then I wrote another simple script and saved it in /PIA as VPNstart.sh:
#!/usr/local/bin/bash
cd /PIA
/usr/local/bin/bash /PIA/run_setup.sh
it is important to change the working directory to where your scripts are, otherwise the wireguard script won't find the authentication certificate (ca.rsa.4096.crt). And I added these lines in /etc/crontab:
@reboot root /PIA/VPNstart.sh
*/15 * * * * root /PIA/refresh_pia_port.sh
This way the VPNstart.sh scripts starts at every reboot, calling run_setup.sh and the rest of the VPN connection procedure.
The refresh_pia_port.sh script is run every 15 minutes to keep the port open.
However, it is important to change the SHELL line in crontab to use bash instead of sh:
SHELL=/usr/local/bin/bash
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin
Hope this helps. My transmission jail has been running smoothly for more than a day now.
YujiTFD
Sorry for bumping it up, but I still fail to get WG working in TrueNAS Jails.
FreeBSD 12.2, VNET, Berkley Packet Filer, fixed IP are on, intend on using as dedicated Bittorrent jails.
Also follow the https://github.com/glorious1/manual-connections, but can't move past number 2, always get this error:
[#] ifconfig wg create name pia
[!] Missing WireGuard kernel support (ifconfig: SIOCIFCREATE2: Invalid argument). Falling back to slow userspace implementation.
[#] wireguard-go pia
/usr/local/bin/wg-quick: line 33: wireguard-go: command not found
[#] ifconfig pia destroy
ifconfig: interface pia does not exist
But when I "pkg install wireguard-go", I get
│   Running wireguard-go is not required because this  │
│   kernel has first class support for WireGuard. For  │
│   information on installing the kernel module,       │
│   please visit:                                      │
│         https://www.wireguard.com/install/           │
ERROR: (pia) 2021/06/21 11:40:18 Failed to create TUN device: open /dev/tun: no such file or directory
What do I do wrong? I have PIA account clock ticking, but can't use it as intended :(
