hescominsoon
- Jul 27, 2016
The title says it all. Linux is perfectly capable of having multiple interfaces run dhcp...what is the logic behind this decision?
after reading this..it's an arbitrary decision by ix systems..yes based on "best practices". however i have every single interface physically attached to its own physical port and each of those ports has it's own VLAN on a separate subnet. for the main interface..yes i have it set to static. the others do not need to be static and i would like the option to put them into dhcp. what's stupid is ALL interfaces are on dhcp right after install. It's only when i go to make one static does the system go and then wreck the initial config. Give us the option to do it how we wish please..:)
