Warning on non-unique serial numbers caused by a cabling issue
calidancer
Hi Guys,
My apologies in advance if a proper answer to this issue was already found and posted in this forum. If that's the case, I would appreciate if someone could provide the link to it.
ISSUE
  • I'm about to create two pools respectively using 2 and 6 drives
  • After clicking on the ADD button from Storage > Pools > CREATE POOL I have been presented with the following warning message:
Warning: There are 8 disks available that have non-unique serial numbers. Non-unique serial numbers can be caused by a cabling issue and adding such disks to a pool can result in lost data.
  • If I then click to the checkbox next to Show disks with non-unique serial numbers, I see all my 8 disks
ENVIRONMENT
  • TrueNAS Core Edition version: TrueNAS-13.0-U5.3
This is a brand new installation.
Thanks in advance.
Regards.
~Calidancer
calidancer
Forgot to say that I did go ahead and created the first pool using the first two disks in mirroring and didn't receive any error. However, the warning message concerns me as I don't want to incur in an unrecoverable data loss scenario.
Thanks.
Regards.
~Calidancer
P.s.: It seems that I can attach pictures to this post by URL only :rolleyes:
Patrick M. Hausen
How are these disks connected?
somethingweird
What kind of drives are these? Just wondering.
Yeah, this is the key question:
No, you should be able to attach an image through any of the usual means: drag & drop, copy/paste, the insert image button in the post editor (not to be confused with the Media button)... Probably more options, too.
Redcoat
Hi Guys,
ISSUE
ENVIRONMENT
Thanks in advance.
Regards.
~Calidancer
Didn't you discuss a similar situation here on the forum back in January- where you were using a RAID card - and receive the solution from @jgreco? Are you in the same or similar situation here?
Or do you have USB-attached drives?
NugentS
It does sound like USB connected drives
@calidancer - we need a proper hardware spec please, as per forum rules. In particular hopw the disks are attached
calidancer
Hi @NugentS, @Redcoat, @Ericloewe, @somethingweird, @Patrick M. Hausen,
My apologies but I have been caught on an emergency yesterday and got only now the change to reply.
Let me answer your questions with more insights about my hardware.
8 x 1TB SATA HDD @ 7200 RPM (recognized by TrueNAS Core Edition as disks of 930.39 GiB each) hosted in a Supermicro 1U (SYS-1026T-6RFT) server witch 144GB of RAM
TrueNAS Core Edition v13.0-U5.3 installed in a separated internal disk (which is not USB)
P.s.: It might sound silly, however I'm still not able to attach any picture to this post and I confirm drag-and-drop does not work. If I click on the tool bar picture icon "Insert image (Ctrl+P)" a dialog box where I can only enter an URL is presented.
Last but not least, I haven't opened a similar post to this one in the past.
Regards.
~Calidancer
Patrick M. Hausen
1. How are they connected? What type is the controller?
2. The "add pictures" button is this one:
Then click on "Insert ..." and select "Thumbnail" oder "Full image".
What's your browser? Do you have any aggressive filtering going on?
X58 + ICH10R, blast from the past...
Anyway, I suspect the backplane may be wired up to the onboard SAS2108 controller... Which means all sorts of mfi things, and mfi is bad.
We can trace this down fairly easily: What's the output of camcontrol devlist?
If it is indeed down to RAID controller nonsense, the solution is simple: Add a suitable HBA (Probably an SAS2008 or SAS2308, since you have SFF-8087 cables) and move over the backplane cables.
calidancer
Hi @Ericloewe ,
Here it is the output of this command:
root@truenas[~]# camcontrol devlist
<SEAGATE ST91000640SS 0002>        at scbus0 target 12 lun 0 (pass0)
<SEAGATE ST91000640SS 0002>        at scbus0 target 13 lun 0 (pass1)
<SEAGATE ST91000640SS 0002>        at scbus0 target 14 lun 0 (pass2)
<SEAGATE ST91000640SS 0002>        at scbus0 target 15 lun 0 (pass3)
<SEAGATE ST91000640SS 0002>        at scbus0 target 16 lun 0 (pass4)
<SEAGATE ST91000640SS 0002>        at scbus0 target 17 lun 0 (pass5)
<SEAGATE ST91000640SS 0002>        at scbus0 target 19 lun 0 (pass6)
<SEAGATE ST91000640SS 0002>        at scbus0 target 20 lun 0 (pass7)
<SATADOM D150QV-L 110520C>         at scbus6 target 0 lun 0 (ada0,pass8)
<AHCI SGPIO Enclosure 2.00 0001>   at scbus7 target 0 lun 0 (ses0,pass9)
Patrick M. Hausen
Redcoat
calidancer
Hi @Redcoat ,
Yes the post is mine but the issue is completely different.
I don't see any connection with the issue I reported in this post.
NugentS
Is it the same server, with the same hardware? If it is, its likley the same sort of problem - a RAID card
I also notice that you haven't provided a proper hardware spec that I requested - just a brief, essentially useless partial overview - containing almost nothing of any use.
Hi @Ericloewe ,
Yeah, that output is fishy. The disks are recognized as SCSI devices but not as SCSI direct-attach disks or some other sort of SCSI disk? Sounds like hardware RAID nonsense to me, but nothing beats opening your server and figuring out where the disks are connected.
jgreco
Resident Grinch
Or at least reporting the output of /var/run/dmesg.boot
calidancer
Guys,
  1. This is a "similar" server but not the same to the one I opened another post back to a long time ago
  2. The "useless" output provided was requested by @Ericloewe
  3. Here it is the output of the /var/run/dmesg.boot file:
Copyright (c) 1992-2021 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 13.1-RELEASE-p7 n245428-4dfb91682c1 TRUENAS amd64
FreeBSD clang version 13.0.0 (git@github.com:llvm/llvm-project.git llvmorg-13.0.0-0-gd7b669b3a303)
VT(vga): text 80x25
CPU: Intel(R) Xeon(R) CPU           E5645  @ 2.40GHz (2400.23-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x206c2  Family=0x6  Model=0x2c  Stepping=2
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x9ee3fd<SSE3,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,DCA,SSE4.1,SSE4.2,POPCNT>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
  VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
  TSC: P-state invariant, performance statistics
real memory  = 154623016960 (147460 MB)
avail memory = 150518468608 (143545 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <SUPERM APIC0923>
FreeBSD/SMP: Multiprocessor System Detected: 24 CPUs
FreeBSD/SMP: 2 package(s) x 6 core(s) x 2 hardware threads
random: unblocking device.
Firmware Warning (ACPI): 32/64X length mismatch in FADT/Gpe0Block: 128/64 (20201113/tbfadt-748)
ioapic1: MADT APIC ID 7 != hw id 8
ioapic0 <Version 2.0> irqs 0-23
ioapic1 <Version 2.0> irqs 24-47
Launching APs: 1 8 23 19 7 20 18 4 11 15 3 16 22 17 9 12 10 13 5 21 14 6 2
random: entropy device external interface
kbd1 at kbdmux0
vtvga0: <VT VGA driver>
aesni0: No AES or SHA support.
padlock0: No ACE support.
acpi0: <SMCI >
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 350
Event timer "HPET1" frequency 14318180 Hz quality 340
Event timer "HPET2" frequency 14318180 Hz quality 340
Event timer "HPET3" frequency 14318180 Hz quality 340
apei0: <ACPI Platform Error Interface> on acpi0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff numa-domain 0 on acpi0
pci0: <ACPI PCI bus> numa-domain 0 on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 numa-domain 0 on pci0
pci1: <ACPI PCI bus> numa-domain 0 on pcib1
pcib2: <ACPI PCI-PCI bridge> at device 3.0 numa-domain 0 on pci0
pci2: <ACPI PCI bus> numa-domain 0 on pcib2
ix0: <Intel(R) X520 82599ES (SFI/SFP+)> port 0xbf80-0xbf9f mem 0xf8f80000-0xf8ffffff,0xf8f7c000-0xf8f7ffff irq 24 at device 0.0 numa-domain 0 on pci2
ix0: Using 2048 TX descriptors and 2048 RX descriptors
ix0: Using 6 RX queues 6 TX queues
ix0: Using MSI-X interrupts with 7 vectors
ix0: allocated for 6 queues
ix0: allocated for 6 rx queues
ix0: Ethernet address: 00:25:90:72:92:4e
ix0: PCI Express Bus: Speed 5.0GT/s Width x8
ix0: eTrack 0x80000208 PHY FW V65535
ix1: <Intel(R) X520 82599ES (SFI/SFP+)> port 0xbf40-0xbf5f mem 0xf8c80000-0xf8cfffff,0xf8f78000-0xf8f7bfff irq 34 at device 0.1 numa-domain 0 on pci2
ix1: Using 2048 TX descriptors and 2048 RX descriptors
ix1: Using 6 RX queues 6 TX queues
ix1: Using MSI-X interrupts with 7 vectors
ix1: allocated for 6 queues
ix1: allocated for 6 rx queues
ix1: Ethernet address: 00:25:90:72:92:4f
ix1: PCI Express Bus: Speed 5.0GT/s Width x8
ix1: eTrack 0x80000208 PHY FW V65535
pcib3: <ACPI PCI-PCI bridge> at device 5.0 numa-domain 0 on pci0
pci3: <ACPI PCI bus> numa-domain 0 on pcib3
mfi0: <LSI MegaSAS Gen2> port 0xc800-0xc8ff mem 0xfac9c000-0xfac9ffff,0xfacc0000-0xfacfffff irq 26 at device 0.0 numa-domain 0 on pci3
mfi0: Using MSI
mfi0: Megaraid SAS driver Ver 4.23
mfi0: FW MaxCmds = 1008, limiting to 128
mfi0: 211357 (752252717s/0x0020/info) - Shutdown command received from host
mfip0: <SCSI Passthrough Bus>mfi0: 211358 (boot + 4s/0x0020/info) - Firmware initialization started (PCI ID 0079/1000/0700/15d9)
mfi0: 211359 (boot + 4s/0x0020/info) - Firmware version 2.130.393-2551
numa-domain 0 on mfi0
mfi0: 211360 (boot + 9s/0x0008/info) - Battery Present
mfi0: 211361 (boot + 9s/0x0020/info) - Package version 12.14.0-0167
mfi0: 211362 (boot + 9s/0x0020/info) - Board Revision
mfi0: 211363 (boot + 27s/0x0002/info) - Inserted: PD 0c(e0xff/s0)
pcib4: <ACPI PCI-PCI bridge> at device 7.0 numa-domain 0 on pci0
pci4: <ACPI PCI bus> numa-domain 0 on pcib4
em0: <Intel(R) PRO/1000 PT 82571EB/82571GB (Copper)> port 0xdf80-0xdf9f mem 0xfade0000-0xfadfffff,0xfadc0000-0xfaddffff irq 30 at device 0.0 numa-domain 0 on pci4
em0: EEPROM V5.6-2
em0: Using 1024 TX descriptors and 1024 RX descriptors
em0: Using an MSI interrupt
em0: Ethernet address: 00:15:17:6c:e7:1e
em1: <Intel(R) PRO/1000 PT 82571EB/82571GB (Copper)> port 0xdf40-0xdf5f mem 0xfad80000-0xfad9ffff,0xfad60000-0xfad7ffff irq 37 at device 0.1 numa-domain 0 on pci4
em1: EEPROM V5.6-2
em1: Using 1024 TX descriptors and 1024 RX descriptors
em1: Using an MSI interrupt
em1: Ethernet address: 00:15:17:6c:e7:1f
pci0: <base peripheral, interrupt controller> at device 20.0 (no driver attached)
pci0: <base peripheral, interrupt controller> at device 20.1 (no driver attached)
pci0: <base peripheral, interrupt controller> at device 20.2 (no driver attached)
pci0: <base peripheral, interrupt controller> at device 20.3 (no driver attached)
ioat0: <TBG IOAT Ch0> mem 0xfaafc000-0xfaafffff irq 43 at device 22.0 numa-domain 0 on pci0
ioat0: Capabilities: 77<Block_Fill,Move_CRC,DCA,Marker_Skipping,CRC,Page_Break>
ioat1: <TBG IOAT Ch1> mem 0xfaaf8000-0xfaafbfff irq 44 at device 22.1 numa-domain 0 on pci0
ioat1: Capabilities: 77<Block_Fill,Move_CRC,DCA,Marker_Skipping,CRC,Page_Break>
ioat2: <TBG IOAT Ch2> mem 0xfaaf4000-0xfaaf7fff irq 45 at device 22.2 numa-domain 0 on pci0
ioat2: Capabilities: 77<Block_Fill,Move_CRC,DCA,Marker_Skipping,CRC,Page_Break>
ioat3: <TBG IOAT Ch3> mem 0xfaaf0000-0xfaaf3fff irq 46 at device 22.3 numa-domain 0 on pci0
ioat3: Capabilities: 77<Block_Fill,Move_CRC,DCA,Marker_Skipping,CRC,Page_Break>
ioat4: <TBG IOAT Ch4> mem 0xfaaec000-0xfaaeffff irq 43 at device 22.4 numa-domain 0 on pci0
ioat4: Capabilities: 77<Block_Fill,Move_CRC,DCA,Marker_Skipping,CRC,Page_Break>
ioat5: <TBG IOAT Ch5> mem 0xfaae8000-0xfaaebfff irq 44 at device 22.5 numa-domain 0 on pci0
ioat5: Capabilities: 77<Block_Fill,Move_CRC,DCA,Marker_Skipping,CRC,Page_Break>
ioat6: <TBG IOAT Ch6> mem 0xfaae4000-0xfaae7fff irq 45 at device 22.6 numa-domain 0 on pci0
ioat6: Capabilities: 77<Block_Fill,Move_CRC,DCA,Marker_Skipping,CRC,Page_Break>
ioat7: <TBG IOAT Ch7> mem 0xfaae0000-0xfaae3fff irq 46 at device 22.7 numa-domain 0 on pci0
ioat7: Capabilities: 77<Block_Fill,Move_CRC,DCA,Marker_Skipping,CRC,Page_Break>
uhci0: <Intel 82801JI (ICH10) USB controller USB-D> port 0xaf80-0xaf9f irq 16 at device 26.0 numa-domain 0 on pci0
uhci0: LegSup = 0x2f00
usbus0 numa-domain 0 on uhci0
usbus0: 12Mbps Full Speed USB v1.0
uhci1: <Intel 82801JI (ICH10) USB controller USB-E> port 0xaf40-0xaf5f irq 21 at device 26.1 numa-domain 0 on pci0
uhci1: LegSup = 0x2f00
usbus1 numa-domain 0 on uhci1
usbus1: 12Mbps Full Speed USB v1.0
uhci2: <Intel 82801JI (ICH10) USB controller USB-F> port 0xaf20-0xaf3f irq 19 at device 26.2 numa-domain 0 on pci0
uhci2: LegSup = 0x2f00
usbus2 numa-domain 0 on uhci2
usbus2: 12Mbps Full Speed USB v1.0
ehci0: <Intel 82801JI (ICH10) USB 2.0 controller USB-B> mem 0xfaade000-0xfaade3ff irq 18 at device 26.7 numa-domain 0 on pci0
usbus3: EHCI version 1.0
usbus3 numa-domain 0 on ehci0
usbus3: 480Mbps High Speed USB v2.0
pcib5: <ACPI PCI-PCI bridge> irq 16 at device 28.0 numa-domain 0 on pci0
pci5: <ACPI PCI bus> numa-domain 0 on pcib5
igb0: <Intel(R) PRO/1000 82576> port 0xef80-0xef9f mem 0xfafe0000-0xfaffffff,0xfafc0000-0xfafdffff,0xfaf9c000-0xfaf9ffff irq 16 at device 0.0 numa-domain 0 on pci5
igb0: EEPROM V1.5-3
igb0: Using 1024 TX descriptors and 1024 RX descriptors
igb0: Using 6 RX queues 6 TX queues
igb0: Using MSI-X interrupts with 7 vectors
igb0: Ethernet address: 00:25:90:72:92:50
igb1: <Intel(R) PRO/1000 82576> port 0xef40-0xef5f mem 0xfaf20000-0xfaf3ffff,0xfaf00000-0xfaf1ffff,0xfaf98000-0xfaf9bfff irq 17 at device 0.1 numa-domain 0 on pci5
igb1: EEPROM V1.5-3
igb1: Using 1024 TX descriptors and 1024 RX descriptors
igb1: Using 6 RX queues 6 TX queues
igb1: Using MSI-X interrupts with 7 vectors
igb1: Ethernet address: 00:25:90:72:92:51
uhci3: <Intel 82801JI (ICH10) USB controller USB-A> port 0xaf00-0xaf1f irq 23 at device 29.0 numa-domain 0 on pci0
uhci3: LegSup = 0x2f00
usbus4 numa-domain 0 on uhci3
usbus4: 12Mbps Full Speed USB v1.0
uhci4: <Intel 82801JI (ICH10) USB controller USB-B> port 0xaec0-0xaedf irq 19 at device 29.1 numa-domain 0 on pci0
uhci4: LegSup = 0x2f00
usbus5 numa-domain 0 on uhci4
usbus5: 12Mbps Full Speed USB v1.0
uhci5: <Intel 82801JI (ICH10) USB controller USB-C> port 0xaea0-0xaebf irq 18 at device 29.2 numa-domain 0 on pci0
uhci5: LegSup = 0x2f00
usbus6 numa-domain 0 on uhci5
usbus6: 12Mbps Full Speed USB v1.0
ehci1: <Intel 82801JI (ICH10) USB 2.0 controller USB-A> mem 0xfaadc000-0xfaadc3ff irq 23 at device 29.7 numa-domain 0 on pci0
usbus7: EHCI version 1.0
usbus7 numa-domain 0 on ehci1
usbus7: 480Mbps High Speed USB v2.0
pcib6: <ACPI PCI-PCI bridge> at device 30.0 numa-domain 0 on pci0
pci6: <ACPI PCI bus> numa-domain 0 on pcib6
vgapci0: <VGA-compatible display> mem 0xf9000000-0xf9ffffff,0xfbefc000-0xfbefffff,0xfb000000-0xfb7fffff irq 18 at device 1.0 numa-domain 0 on pci6
vgapci0: Boot video device
isab0: <PCI-ISA bridge> at device 31.0 numa-domain 0 on pci0
isa0: <ISA bus> numa-domain 0 on isab0
ahci0: <Intel ICH10 AHCI SATA controller> port 0xaff0-0xaff7,0xafac-0xafaf,0xafe0-0xafe7,0xafa8-0xafab,0xae80-0xae9f mem 0xfaada000-0xfaada7ff irq 19 at device 31.2 numa-domain 0 on pci0
ahci0: AHCI v1.20 with 6 3Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
ahciem0: <AHCI enclosure management bridge> on ahci0
acpi_button0: <Power Button> on acpi0
ipmi0: <IPMI System Interface> port 0xca2-0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
ichwd0: <Intel ICH10R watchdog timer> on isa0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xc9fff,0xd0800-0xd17ff,0xd1800-0xd27ff pnpid ORM0000 on isa0
superio0: <Winbond 83627DHG-P> at port 0x2e-0x2f on isa0
wbwd0: <Winbond 83627DHG-P (0xb0/0x73) Watchdog Timer> at WDT ldn 0x08 on superio0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
Timecounter "TSC-low" frequency 1200042462 Hz quality 1000
Timecounters tick every 1.000 msec
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
ugen7.1: <Intel EHCI root HUB> at usbus7
ugen4.1: <Intel UHCI root HUB> at usbus4
ugen2.1: <Intel UHCI root HUB> at usbus2
ugen1.1: <Intel UHCI root HUB> at usbus1
ugen5.1: <Intel UHCI root HUB> at usbus5
ugen6.1: <Intel UHCI root HUB> at usbus6
mfid0 numa-domain 0 on mfi0
mfid0: 952720MB (1951170560 sectors) RAID volume (no label) is optimal
ugen0.1: <Intel UHCI root HUB> at usbus0
ugen3.1: <Intel EHCI root HUB> at usbus3
mfi0: 211364 (boot + 27s/0x0002/info) - Inserted: PD 0c(e0xff/s0) Info: enclPd=ffff, scsiType=0, portMap=00, sasAddr=5000c50041uhub4 numa-domain 0 on usbus1
uhub4: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
5c5691,0000000000000000
mfi0: 211365 (boot + 27s/0x0002/info) - Inserted: PD 0d(e0xff/s1)
sysctl_warn_reuse: can't re-use a leaf (dev.uhub.%parent)!
uhub5 numa-domain 0 on usbus0
uhub5: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
uhub2 numa-domain 0 on usbus4
uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
mfid1 numa-domain 0 on mfi0
mfid1: 952720MB (1951170560 sectors) RAID volume (no label) is optimal
uhub0 numa-domain 0 on usbus2
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
uhub6 numa-domain 0 on usbus3
uhub6: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
uhub1 numa-domain 0 on usbus7
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus7
mfid2 numa-domain 0 on mfi0
mfid2: 952720MB (1951170560 sectors) RAID volume (no label) is optimal
uhub3 numa-domain 0 on usbus6
uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
uhub7 numa-domain 0 on usbus5
uhub7: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
mfid3 numa-domain 0 on mfi0
mfid3: 952720MB (1951170560 sectors) RAID volume (no label) is optimal
mfid4 numa-domain 0 on mfi0
mfid4: 952720MB (1951170560 sectors) RAID volume (no label) is optimal
mfid5 numa-domain 0 on mfi0
mfid5: 952720MB (1951170560 sectors) RAID volume (no label) is optimal
mfid6 numa-domain 0 on mfi0
mfid6: 952720MB (1951170560 sectors) RAID volume (no label) is optimal
mfid7 numa-domain 0 on mfi0
mfid7: 952720MB (1951170560 sectors) RAID volume (no label) is optimal
ipmi0: IPMI device rev. 1, firmware rev. 2.52, version 2.0, device support mask 0xbf
ipmi0: Number of channels 2
ipmi0: Attached watchdog
ipmi0: Establishing power cycle handler
Trying to mount root from zfs:boot-pool/ROOT/default []...
mfi0: 211366 (boot + 27s/0x0002/info) - Inserted: PD 0d(e0xff/s1) Info: enclPd=ffff, scsiType=0, portMap=01, sasAddr=5000c500415d1b0d,0000000000000000
mfi0: 211367 (boot + 27s/0x0002/info) - Inserted: PD 0e(e0xff/s2)
mfi0: 211368 (boot + 27s/0x0002/info) - Inserted: PD 0e(e0xff/s2) Info: enclPd=ffff, scsiType=0, portMap=02, sasAddr=5000c500415d6975,0000000000000000
mfi0: 211369 (boot + 27s/0x0002/info) - Inserted: PD 0f(e0xff/s3)
mfi0: 211370 (boot + 27s/0x0002/info) - Inserted: PD 0f(e0xff/s3) Info: enclPd=ffff, scsiType=0, portMap=03, sasAddr=5000c500415d4315,0000000000000000
mfi0: 211371 (boot + 27s/0x0002/info) - Inserted: PD 10(e0xff/s4)
mfi0: 211372 (boot + 27s/0x0002/info) - Inserted: PD 10(e0xff/s4) Info: enclPd=ffff, scsiType=0, portMap=04, sasAddr=5000c500415d1f5d,0000000000000000
mfi0: 211373 (boot + 27s/0x0002/info) - Inserted: PD 11(e0xff/s5)
mfi0: 211374 (boot + 27s/0x0002/info) - Inserted: PD 11(e0xff/s5) Info: enclPd=ffff, scsiType=0, portMap=05, sasAddr=5000c500415d1d01,0000000000000000
mfi0: 211375 (boot + 27s/0x0002/info) - Inserted: PD 13(e0xff/s6)
mfi0: 211376 (boot + 27s/0x0002/info) - Inserted: PD 13(e0xff/s6) Info: enclPd=ffff, scsiType=0, portMap=06, sasAddr=5000c500415d687d,0000000000000000
mfi0: 211377 (boot + 27s/0x0002/info) - Inserted: PD 14(e0xff/s7)
mfi0: 211378 (boot + 27s/0x0002/info) - Inserted: PD 14(e0xff/s7) Info: enclPd=ffff, scsiType=0, portMap=07, sasAddr=5000c50041ae30f9,0000000000000000
mfi0: 211379 (752253343s/0x0020/info) - Time established as 11/02/23 15:15:43; (37 seconds since power on)
mfi0: 211380 (752253366s/0x0008/info) - Battery started charging
mfi0: 211381 (752253366s/0x0008/info) - Battery temperature is normal
mfi0: 211382 (752253366s/0x0008/WARN) - Battery requires reconditioning; please initiate a LEARN cycle
mfi0: 211383 (752253366s/0x0008/WARN) - BBU disabled; changing WB virtual disks to WT, Forced WB VDs are not affected
mfi0: 211384 (752253380s/0x0020/info) - Host driver is loaded and operational
ses0 at ahciem0 bus 0 scbus7 target 0 lun 0
ses0: <AHCI SGPIO Enclosure 2.00 0001> SEMB S-E-S 2.00 device
ses0: SEMB SES Device
ada0 at ahcich5 bus 0 scbus6 target 0 lun 0
ada0: <SATADOM D150QV-L 110520C> ATA8-ACS SATA 2.x device
ada0: Serial Number 20111219AA0000000034
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: 15272MB (31277232 512 byte sectors)
pass0 at mfi0 bus 0 scbus0 target 12 lun 0
pass0: <SEAGATE ST91000640SS 0002> Fixed Uninstalled SPC-4 SCSI device
pass0: Serial Number 9XG19RMT00009236TWEF
pass0: 150.000MB/s transfers
pass0: Command Queueing enabled
pass1 at mfi0 bus 0 scbus0 target 13 lun 0
pass1: <SEAGATE ST91000640SS 0002> Fixed Uninstalled SPC-4 SCSI device
ses0: pass8,ada0 in 'Slot 05', SATA Slot: scbus6 target 0
pass1: Serial Number 9XG1AA5K00009235T4HW
pass1: 150.000MB/s transfers
pass1: Command Queueing enabled
pass2 at mfi0 bus 0 scbus0 target 14 lun 0
pass2: <SEAGATE ST91000640SS 0002> Fixed Uninstalled SPC-4 SCSI device
pass2: Serial Number 9XG1A6PP00009236TYBM
pass2: 150.000MB/s transfers
pass2: Command Queueing enabled
pass3 at mfi0 bus 0 scbus0 target 15 lun 0
pass3: <SEAGATE ST91000640SS 0002> Fixed Uninstalled SPC-4 SCSI device
pass3: Serial Number 9XG1AAJX00009236TWP0
pass3: 150.000MB/s transfers
pass3: Command Queueing enabled
pass4 at mfi0 bus 0 scbus0 target 16 lun 0
pass4: <SEAGATE ST91000640SS 0002> Fixed Uninstalled SPC-4 SCSI device
pass4: Serial Number 9XG1AA1B00009236TXMU
pass4: 150.000MB/s transfers
pass4: Command Queueing enabled
pass5 at mfi0 bus 0 scbus0 target 17 lun 0
pass5: <SEAGATE ST91000640SS 0002> Fixed Uninstalled SPC-4 SCSI device
pass5: Serial Number 9XG1AA6N00009235T5HP
pass5: 150.000MB/s transfers
pass5: Command Queueing enabled
pass6 at mfi0 bus 0 scbus0 target 19 lun 0
pass6: <SEAGATE ST91000640SS 0002> Fixed Uninstalled SPC-4 SCSI device
pass6: Serial Number 9XG1A6LB00009236TYQG
pass6: 150.000MB/s transfers
pass6: Command Queueing enabled
pass7 at mfi0 bus 0 scbus0 target 20 lun 0
pass7: <SEAGATE ST91000640SS 0002> Fixed Uninstalled SPC-4 SCSI device
pass7: Serial Number 9XG1MJ5600009241JL70
pass7: 150.000MB/s transfers
pass7: Command Queueing enabled
uhub4: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub5: 2 ports with 2 removable, self powered
uhub7: 2 ports with 2 removable, self powered
uhub3: 2 ports with 2 removable, self powered
uhub0: 2 ports with 2 removable, self powered
Root mount waiting for: usbus3 usbus7
uhub6: 6 ports with 6 removable, self powered
uhub1: 6 ports with 6 removable, self powered
ugen1.2: <Winbond Electronics Corp Hermon USB hidmouse Device> at usbus1
ums0 numa-domain 0 on uhub4
ums0: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 2> on usbus1
ums0: 3 buttons and [Z] coordinates ID=0
ukbd0 numa-domain 0 on uhub4
ukbd0: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 2> on usbus1
kbd2 at ukbd0
ichsmb0: <Intel 82801JI (ICH10) SMBus controller> port 0x400-0x41f mem 0xfaad8000-0xfaad80ff irq 18 at device 31.3 numa-domain 0 on pci0
smbus0: <System Management Bus> numa-domain 0 on ichsmb0
lo0: link state changed to UP
igb0: link state changed to UP
debugnet_any_ifnet_update: Bad dn_init result from igb0 (ifp 0xfffff8124437d800), ignoring.
igb1: link state changed to UP
debugnet_any_ifnet_update: Bad dn_init result from igb1 (ifp 0xfffff801027af800), ignoring.
CPU: Intel(R) Xeon(R) CPU           E5645  @ 2.40GHz (2400.08-MHz K8-class CPU)
  Structured Extended Features3=0x9c000000<IBPB,STIBP,L1DFL,SSBD>
igb0: link state changed to DOWN
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI>[/COLOR]
Thanks.
P.s.: If some can please provide some pictures (a sequence) on how to upload pictures, that would be great. I'm still unable to upload anything on this post... that's incredible and very annoying!
