SOLVED Volume size appears incorrect
ADUR
Hi everyone,
I have seen a lot of posts of this kind on the forum, and even if I've been through some of them, I unfortunnately didn't solve my issue :/
Here is my issue :
I have a Freenas running 11.1U6 version
I have only one big storage supposed to be sized at 6Tb, and never have I done the "zfs irreversible" update (I still have this message : New feature flags are available for volume NAS-GDA2. Refer to the "Upgrading a ZFS Pool" section of the User Guide for instructions. )
I have issues with storage, that is not freeing space (I deleted about 1Tb and quite nothing happened on the space left).
It also look like I have locked snapshots, that are probably part of the problem here.
And last of all, I'm pretty sure I lost part of my storage here, doesn't it look weird ? Where are my 6Tb ..?
Here is my storage :
The "Sync" storage is a sync between this NAS and another, on the same network elsewhere. As I understand it, the synhronized data are stored on this NAS, it looks OK
My snapshots (in yellow the one locked):
zfs destroy of the two snapshot in yellow :
root@nas-gda2:/mnt/NAS-GDA2/nfs/GDA2 # zfs destroy NAS-GDA2/nfs/Sync@auto-20180625.1437-1h
cannot destroy snapshot NAS-GDA2/nfs/Sync@auto-20180625.1437-1h: dataset is busy
root@nas-gda2:/mnt/NAS-GDA2/nfs/GDA2 # zfs destroy NAS-GDA2/nfs/Sync@auto-20180625.1507-1h
cannot destroy snapshot NAS-GDA2/nfs/Sync@auto-20180625.1507-1h: dataset is busy
zfs list -t all -r NAS-GDA2
root@nas-gda2:/mnt/NAS-GDA2/nfs/GDA2 # zfs list -t all -r NAS-GDA2
NAME        USED  AVAIL  REFER  MOUNTPOINT
NAS-GDA2        3.13T   275G   140K  /mnt/NAS-GDA2
NAS-GDA2@auto-20190304.0400-1d                                                    93K      -   140K  -
NAS-GDA2/.system        168M   275G   151K  legacy
NAS-GDA2/.system@manual-20150730                                                 105K      -  88.3M  -
NAS-GDA2/.system@manual-20150730-1420                                            105K      -  88.3M  -
NAS-GDA2/.system/configs-903a2a7d45924e86a448cccd86aa67c2                       42.4M   275G  42.3M  legacy
NAS-GDA2/.system/configs-903a2a7d45924e86a448cccd86aa67c2@manual-20150730           0      -   140K  -
NAS-GDA2/.system/configs-903a2a7d45924e86a448cccd86aa67c2@manual-20150730-1420      0      -   140K  -
NAS-GDA2/.system/cores                                                          18.3M   275G  16.4M  legacy
NAS-GDA2/.system/cores@manual-20150730                                              0      -  1.98M  -
NAS-GDA2/.system/cores@manual-20150730-1420                                         0      -  1.98M  -
NAS-GDA2/.system/rrd-903a2a7d45924e86a448cccd86aa67c2                            232K   275G   140K  legacy
NAS-GDA2/.system/rrd-903a2a7d45924e86a448cccd86aa67c2@manual-20150730               0      -   140K  -
NAS-GDA2/.system/rrd-903a2a7d45924e86a448cccd86aa67c2@manual-20150730-1420          0      -   140K  -
NAS-GDA2/.system/samba4                                                         5.81M   275G  5.35M  legacy
NAS-GDA2/.system/samba4@manual-20150730                                          122K      -   459K  -
NAS-GDA2/.system/samba4@manual-20150730-1420                                     140K      -   477K  -
NAS-GDA2/.system/syslog-903a2a7d45924e86a448cccd86aa67c2                        12.6M   275G  11.6M  legacy
NAS-GDA2/.system/syslog-903a2a7d45924e86a448cccd86aa67c2@manual-20150730         198K      -   878K  -
NAS-GDA2/.system/syslog-903a2a7d45924e86a448cccd86aa67c2@manual-20150730-1420    279K      -   959K  -
NAS-GDA2/jails        7.49G   275G   186K  /mnt/NAS-GDA2/jails
NAS-GDA2/jails/.warden-template-pluginjail--x64                                 3.16M   275G  3.16M  /mnt/NAS-GDA2/jails/.warden-template-pluginjail--x64
NAS-GDA2/jails/.warden-template-standard--x64                                    626M   275G   626M  /mnt/NAS-GDA2/jails/.warden-template-standard--x64
NAS-GDA2/jails/.warden-template-standard--x64-20140317184634                    2.06G   275G  2.06G  /mnt/NAS-GDA2/jails/.warden-template-standard--x64-20140317184634
NAS-GDA2/jails/.warden-template-standard--x64-20140323023236                    2.12G   275G  2.06G  /mnt/NAS-GDA2/jails/.warden-template-standard--x64-20140323023236
NAS-GDA2/jails/.warden-template-standard--x64-20140323023236@clean              71.4M      -  2.06G  -
NAS-GDA2/jails/.warden-template-standard-9.3-x64                                2.13G   275G  2.06G  /mnt/NAS-GDA2/jails/.warden-template-standard-9.3-x64
NAS-GDA2/jails/.warden-template-standard-9.3-x64@clean                          71.4M      -  2.06G  -
NAS-GDA2/jails/BackupPC3                                                         574M   275G  2.30G  /mnt/NAS-GDA2/jails/BackupPC3
NAS-GDA2/jails/BackupPC3@auto-20190303.1729-1d                                  77.7M      -  2.30G  -
NAS-GDA2/nfs        3.13T   275G  1.32T  /mnt/NAS-GDA2/nfs
NAS-GDA2/nfs/GDA2        883G   275G   878G  /mnt/NAS-GDA2/nfs/GDA2
NAS-GDA2/nfs/GDA2@auto-20190304.1539-1d                                          105K      -   878G  -
NAS-GDA2/nfs/GDA2/HLP                                                           5.16G   280G    93K  -
NAS-GDA2/nfs/Sync        966G   275G   689G  /mnt/NAS-GDA2/nfs/Sync
NAS-GDA2/nfs/Sync@auto-20180625.1437-1h                                          232K      -   317G  -
NAS-GDA2/nfs/Sync@auto-20180625.1507-1h                                          232K      -   317G  -
NAS-GDA2/nfs/Sync@auto-20190304.1518-1h                                             0      -   689G  -
NAS-GDA2/nfs/Sync@auto-20190304.1548-1h                                             0      -   689G  -
zfs list -t all -r NAS-GDA2/nfs (to lower to the storage I'd like to have 6Tb)
root@nas-gda2:/mnt/NAS-GDA2/nfs/GDA2 # zfs list -t all -r NAS-GDA2/nfs
I already deleted a bunch of snapshot, and it freed a few space, but really not so much.
Of course df -h don't work well (everytime I delete something, it only substract the space I deleted from the available space)
Later this week, I will try 2 things that I'm not able to try now :
- Reboot the server
- Upgrade to 11.1U7
I will be glad of every hint you can give me, or if you can explain me where my 3Tb are !
Many thanks for your time !
Best regards,
ADUR
garm
What is the configuration of your pool?
Post the printout of zpool status -v
ADUR
Hi garm =)
Here we are :
root@nas-gda2:/mnt/NAS-GDA2/nfs/GDA2 # zpool status -v
  pool: NAS-GDA2
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
        still be used, but some features are unavailable.
  scan: scrub repaired 0 in 0 days 08:36:34 with 0 errors on Sat Mar  2 02:45:12 2019
        NAS-GDA2                                        ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/884730ad-a893-11e3-aa4c-a0481cb833a0  ONLINE       0     0     0
            gptid/88a050dd-a893-11e3-aa4c-a0481cb833a0  ONLINE       0     0     0
            gptid/7cc35920-10dc-11e8-ba32-a0481cb833a0  ONLINE       0     0     0
            gptid/894bb460-a893-11e3-aa4c-a0481cb833a0  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:02:23 with 0 errors on Mon Feb 25 03:47:24 2019
        freenas-boot  ONLINE       0     0     0
          da0p2     ONLINE       0     0     0
I'll give it a restart in a few hours FI
Thank you for your interest on this case =)
garm
Is the culprit, you have 1 TiB worth of snapshots in this dataset. Do you use ZFS Send/Receive?
With RaidZ2 you don’t get 6 TiB with 4x2 TB drives, you get ~ 3.6 TiB
ADUR
Oh my bad about my understanding of the space supposed to be available !
Hum I was already sure it was under nfs, but I don't understand which snapshot is responsible ...
If I take the ones under NAS-GDA2/nfs :
I'm able to delete the ones of today, but they use 0 space.
And I don't know what ZFS send/receive is, so at first glance I would answer "no", but not sure about this one.
You think that if I was able to delete the locked snaps, I would free about 1Tb ?
In any case, kudos for your help of pointing the issue !
ADUR
I found help on this post :
https://www.ixsystems.com/community/threads/can't-delete-snapshots.24911/
There was a hold tag on my snapshot.
Here is what I've done :
root@nas-gda2:/mnt/NAS-GDA2/nfs/GDA2 # zfs holds NAS-GDA2/nfs/Sync@auto-20180625.1437-1h
NAME                                     TAG           TIMESTAMP
NAS-GDA2/nfs/Sync@auto-20180625.1437-1h  freenas:repl  Mon Jun 25 14:37 2018
root@nas-gda2:/mnt/NAS-GDA2/nfs/GDA2 # zfs release -r freenas:repl NAS-GDA2/nfs/Sync@auto-20180625.1437-1h
root@nas-gda2:/mnt/NAS-GDA2/nfs/GDA2 # zfs release -r freenas:repl NAS-GDA2/nfs/Sync@auto-20180625.1507-1h
root@nas-gda2:/mnt/NAS-GDA2/nfs/GDA2 # zfs list -t snapshot -r NAS-GDA2/nfs
NAS-GDA2/nfs/GDA2@auto-20190304.1539-1d   174K      -   878G  -
NAS-GDA2/nfs/Sync@auto-20190304.1648-1h      0      -   689G  -
NAS-GDA2/nfs/Sync@auto-20190304.1718-1h      0      -   689G  -
could not find any snapshots to destroy; check snapshot names.
I finally deleted also all of the snapshots under NAS-GDA2/nfs, to be sure none of them keeped space.
I now have 552Gb available on my NAS-GDA2/nfs volume.
I also assume that it will probably free some more space if I let the deletion make it's stuff (I've found on another post that freeing space is asynchroneous)
Many thanks @garm for your help, I hope it will be enough for my use !
I close this post, what a fast resolve !
pro lamer
Has it actually happen? What is your free space now?
Sent from my phone
ADUR
Sent from my phone
Hi pro lamer, sorry for the long time I took to answer !
The free space didn't grow up after the actions I took, and since we still use the NAS and some data have been added, the remaining space today isn't relevant for your point unfortunately.
But a day after the actions, the free space was still 552Gb, and that's enough for what I wanted my NAS to have !
Feel free to ask anything else, I'll answer quicker this time !
