using different Hard drives
Thomate1375
im just started testing out the TrueNas software on some old hardware... the problem is that I only have 2 HDD with different sizes (500GB and 600gb) and TrueNas instaled on a 120gb SSD
The Installation was easy so far, but every time I try to create a pool theres an error message that I cant build a pool with differnt sized HDDs. I wont mind if the 100gb more on the bigger HDD is not useable but I cant find any option to set this up
You need to check the "Force" option at the bottom for pool creation to proceed when there's a warning like that.
Can you share more details of what you're doing and what is reported in terms of error? (screenshots or copied text in code tags would be most helpful)
