The df command will not do what you want in FreeNAS 9.2 or below because it repartitions the drive and you will only see what is mounted. This will work however fro FreeNAS 9.3 but the values will not be clear indicators of the actual USB capacity, they will be listed as much lower due to formatting and such. For instance my 8GB flash drive shows up as 5.4GB in FreeNAS 9.3, the same 8GB drive would be indicated as 926MB in FreeNAS 9.2.1.9.
The only ways I know how to check it and this is a simple way....
1) Reboot your FreeNAS machine.
2) After it's up and running, hit the Scroll Lock key.
3) Press Page Up key and locate the section where your drives are being identified or
Or, if you know the device name (likely da0)
2) Open the Shell in the GUI and type
cat /var/log/messages | grep da0
3) Now look only for da0 and in those messages you should see something similar (this is mine and just round up the last line to 8GB)
Jan 2 10:02:50 freenas da0 at umass-sim0 bus 0 scbus8 target 0 lun 0
Jan 2 10:02:50 freenas da0: < Patriot Memory PMAP> Removable Direct Access SCSI-0 device
Jan 2 10:02:50 freenas da0: Serial Number 07B31101001835E5
Jan 2 10:02:50 freenas da0: 40.000MB/s transfers
Jan 2 10:02:50 freenas da0: 7640MB (15646720 512 byte sectors: 255H 63S/T 973C
