ChaosUK
- Sep 3, 2016
Hi
i am using unifi ap at home. i was using a controller on my windows pc to do the updates so far.
I figure out it would be much easier to just install controler on my Truenas.
Pluign installs fine. I exported all of the settings from my "old" controller. It seems to work fine but my AP just shows offline.
I tried resetting it but notthing changes.
Just to test i installed to controller on another windows machine and resored my backup. It worked without a problem AP showed as "ADAPT" and started working straight away.
I can see Truenas controler on my mobile app but i am not able to connect.
Can anyone help?
Can anyone help?
