Understanding S.M.A.R.T. test results
Askejm
When I bought the pc for my nas, it came with a handful of old drives. One of them (ada2) has been whining a lot about offline sectors. I don't plan on storing anything important on any of these old drives, but I just wanted to know what these smart test results mean
You'll need to get more information from it by going to the shell and typing smartctl -a /dev/ada2
Askejm
Alright here you go
Model Family:     Western Digital Caviar Green
Device Model:     WDC WD10EAVS-00D7B0
Serial Number:    WD-WCAU41945723
LU WWN Device Id: 5 0014ee 2ac931701
Firmware Version: 01.01A01
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.5, 3.0 Gb/s
Local Time is:    Sat Feb  5 20:11:13 2022 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        been run.
data collection:                (21600) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 248) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303f) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   199   191   051    Pre-fail  Always       -       23827
  3 Spin_Up_Time            0x0027   157   155   021    Pre-fail  Always       -       7108
  4 Start_Stop_Count        0x0032   088   088   000    Old_age   Always       -       12967
  5 Reallocated_Sector_Ct   0x0033   172   172   140    Pre-fail  Always       -       219
  7 Seek_Error_Rate         0x002e   100   253   051    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   060   060   000    Old_age   Always       -       29496
 10 Spin_Retry_Count        0x0032   100   100   051    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   051    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   098   098   000    Old_age   Always       -       2782
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       76
193 Load_Cycle_Count        0x0032   196   196   000    Old_age   Always       -       12936
194 Temperature_Celsius     0x0022   109   094   000    Old_age   Always       -       41
196 Reallocated_Event_Count 0x0032   001   001   000    Old_age   Always       -       254
197 Current_Pending_Sector  0x0032   199   199   000    Old_age   Always       -       171
198 Offline_Uncorrectable   0x0030   200   199   000    Old_age   Offline      -       136
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   199   197   051    Old_age   Offline      -       227
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed: read failure       90%     29491         1399113418
# 2  Short offline       Completed: read failure       90%     29172         1399113418
Etorix
Non-zero values at #5, 196, 197, 198 and 200 are not good: This old drive is failing. Discard it.
Askejm
Ok how much usually before its bad or really bad? My 3 ironwolf drives all have 10 reallocated sectors
Etorix
Not much, and then it's how it evolves. The drive already has 219 reallocated sectors (definitively dead) and 171 suspicious ones. Given its age, other sectors will follow.
Reallocated sectors should be a valid cause for RMA, if the Ironwolf are still under warranty. Else, run regular SMART test on the Ironwolf drives and see if reallocated/pending counts increase.
