bigbraindecisions
- Oct 4, 2022
I have a TrueNAS Core server with a Realtek 2.5G NIC, that was happily running on 13.0-U1.
This night I decided to upgrade TrueNAS to 13.0-U2, but thanks to the fantastic decision of disabling NICs without telling anyone about it, if not by mentioning it in the changelog, I'm not able to reach my server anymore.
So, basically, my server has been "killed" by the TrueNAS team, that deliberately decided to push an update that disabled stuff that may be required to operate as a "bug fix".
Was that so hard to add a notification saying "consider disabling your 2.5G Realtek if you're using iSCSI shares as it may cause issues", add a check to see if that NIC was the only NIC available, or eventually, add a check to see if there's at least one iSCSI share running on the server? Doesn't seem hard to me.
I'm quite new with TrueNAS, so I would like to ask you two things:
- There's any solution to this big brain idea? My server is headless, only has that NIC and it's a few hundred kilometers from my current location.
- Is the TrueNAS team used to work like this? I was interested in Scale and TrueNAS products, but hell, if this is their usual workflow I'm definitely going to pack up soon.
