TrueNAS SCALE apt-src
pbrunnen
Does anyone know what the apt-src URL is? I'm trying to locate the source for the customized truenas-amd64 kernel. I checked the documentation, but I've not been able to locate the details.
Thanks!
ornias
All source is on github.
The apt repo's are shown when doing apt-get update for example and there should be a file somewhere either on your system or the scalebuild github repo.
pbrunnen
Hi Ornias,
Yea, I've kinda come to the conclusion that I can't use the apt method for getting the individual source components and I'll have to do a full build environment to get what I need, so I'm prepping a Deb10 system now. Currently I need to build a Marvell SATA driver that is not in Linux mainline for the TrueNAS kernel.
Thanks!
stavros-k
Hi Ornias,
Thanks!
A suggestion on iX Jira or even a PR for this would be nice and might help others that need the same SATA driver!
pbrunnen
Hi StavrosMadK,
An iX Jira suggestion ticket was created. NAS-110414
So far however I'm having issues with stability of the driver, so this may be a lost cause.
stavros-k
Hi StavrosMadK,
Ahh, for some reason iX decided to have all new tickets private... So i can't upvote the suggestion :)
Hopefully, you will get your driver in before release!
