TrueNAS-SCALE-22.02.2 - Deluge - Stuck on "Downloading" (Permissions?)
Venger
Hi Team,
First day using TrueNAS Scale, so be gently on me (Please!)
When a fresh torrent file has been added to the Deluge, it just sits on "Downloading.." and doesn't move.
Looks like a permission issue to writing to the share, had the same sort of issue when using unraid.
Dataset permissions has been set automatically by the app itself:
Can anyone point me to the right direction?
Regards
Dave
morganL
Captain Morgan
Administrator
Are any other Apps working for you?
Is general storage OK?
dserruya
Hey, had same issue.
If you using HostPath when you connect to your Deluge UI you need to set the folders correctly.
