TrueNAS-SCALE-21.06-BETA.1 Virtual Machines stuck at 800x600
oumpa31
I created a VM to test windows and the Screen size is stuck at 800x600 even if i go into the display and change VLC size to 1920x1080.
DaSnipe
You need to install display drivers for Virtio
I downloaded the Virtio ISO and loaded it when I installed my Windows 10 as a second CD drive, then searched for drivers
Kasazn
