Truenas not booting
Ry-Guy
I recently updated to the newest version of truenas scale, it seemed to have went fine but when I rebooted the system it will no longer boot, the issue seems to be with grub, because every drive shows up as an unknown filesystem, even though they are all ext4, and when I run insmod ext4 I get this error
error: file /grub@/x86_64-efi/ext4.mod' not found.
Any help fixing this would be much appreciated.
probain
Did you by any chance update your boot pool?
Ry-Guy
Yes I did true as prompted me that the pool could be updated so I updated it.
probain
I'm guessing that you saw it in the shell.
'till next time. Don't do such actions outside of the GUI.
Because Grub doesn't understand that version of ZFS. So unfortunately your only recourse is reinstall and apply your config that you saved when upgrading. Because you saved your config, right?
If you didn't. Then you should still be able to import your pools. It's just the other configured things that you'll have to do anew.
Ry-Guy
I was prompted in the notification panel that there were updates available to the pools. I did save my config, so I will reinstall then. Thank you for all your help.
