while ago (almost 1y
) I opened this discussion, despite I received many suggestions, today I was looking into this, and this user suggested this minimum hardware: https://www.truenas.com/community/threads/home-nas-solution-how-to-contain-costs.105588/post-726720
I'm not looking at that anymore due to a couple of reasons:
1. I don't need the DEV machine to sit on the NAS anymore, even if I could with the hardware I'm gonna post. So things like Xeon and Supermicro are really not necessary.
2. It's quite difficult to get hardware in UK, mainly warranty for the super expensive new hardware that TrueNas Scale requires, so I'd rather buy commercial hardware and buy it new to get warranty, and even that costs less probably :D .
Certainly I won't have all the enterprise perks like the IPMI, but is that really necessary?
I've also read that some ASRock has IPMI, I've never seen it but whatever, if so, cool!
So, I was thinking to the following hardware, but the compatible one mentioned by this company is dated to the:
Intel Core i3-6300 LGA 1151
Two cores with hyper-threading but no turbo boost.
Intel Core i3-8300
The Core i3-8300 trades hyper-threading for two additional physical cores
Ideally, is it not better to take something more recent?
ark.intel.com
Or whatever is on this list:
https://ark.intel.com/content/www/u...1=3,4&0_ECCMemory=True&1_Filter-Family=122139
Interestingly, I didn't find so many info about recent supported motherboards, or the issue is that TrueNas Core supports only LGA 1151 as most recent socket?
My expectations and specs are the following:
1. 4 x12TB (CMR), or maybe 8TB disks
2. Mainly used for data storage and backups from Time Machine, even though I have plenty of external disks for that at the moment (bad mistake)... The data storage shouldn't exceed 5TB in total including Time Machine.
3. I'm gonna move next year and I want to install video cameras, so this NAS should have enough performance for that too.
4. My router has 1Gb/s ports, so, I'm tight and this is not gonna change at the moment unless I change the network card, but it's not necessary. I don't write much, once I store my data, daily file editing is a joke, only videocameras will be the constant workload...
5. Everything should be encrypted, so CPU performance is important, but the CPU I posted should handle it well...
Is there any reason why I shouldn't go for Core instead of Scale?
With Core, I could be around 1k pounds, with Scale, oh dear, much more...
Intel Core i3-8300
Intel® Core™ i3-13100TE Processor (12M Cache, up to 4.10 GHz) - Product Specifications | Intel
Intel® Core™ i3-13100TE Processor (12M Cache, up to 4.10 GHz) quick reference with specifications, features, and technologies.
