Thoughts on case/PSU: U-Nas 810A
rossthompson89
I'm finally about finished with my NAS build with the exception of case, PSU and drives. In reference to the linked thread, please note that I ended up going with completely different hardware that was in the OP. Anywho... I'm considering the U-NAS 810A case, but upon checking it out I realized that I will need a special server power supply for the case. Would anyone be kind enough to sanity check these for compatibility? I have yet to build an "official" server, so I am still learning about server hardware components for myself.
Mobo/CPU combo:
Motherboard: https://www.ebay.com/itm/192561781616
CPU: https://www.ebay.com/itm/132816622826
Case/PSU combo:
Case: http://www.u-nas.com/xcart/product.php?productid=17640
PSU: https://www.ebay.com/itm/262544647746
Any thoughts/opinions/feedback would be awesome.
rossthompson89
Screenshot of the cooler master PSU calculator. According to this 400w should be plenty for this rig.
rossthompson89
These were the other cases I came down to if the server case mentioned above doesn't look like it's going to work out. I should mention that I have chosen these cases for their smaller space footprint and just like the idea of something compact.
BitFenix Phenom M BFC-PHM-300-KKXKK-RP:
https://www.newegg.com/Product/Product.aspx?Item=N82E16811345035
Fractal Node 804:
https://www.fractal-design.com/home/product/cases/node-series/node-804
In the event of going with one of the cases above, I'll end up using the following PSU:
https://www.ebay.com/itm/163279426704
Chris Moore
