Hi! I'm hoping I might get lucky and find someone here with a lot of experience with the HP Proliant DL380e G8 and FreeNAS.
I bought one of these recently from a server reseller in the LFF configuration, that has a total of 14 SATA/SAS drive bays. It has 12 in front and an additional 2 in the rear, that seem to occupy a space often used for other HP expansion products. It came with only 2 2TB HP SAS drives installed, but I was able to populate it with 12 more Western Digital Red 6TB drives. I followed the instructions on the YouTube video linked here:
www.youtube.com
That let me put the B120i controller card in the server into HBA mode successfully.
Then, FreeNAS was able to see and use all of my drives. (I was warned that without using real HP drives, I could run into weird issues like fans ramping up to high speeds and status lights not working on the drive trays. I did have that with a Hitachi drive I tried to use at one point, but the WD Red drives seem to be cooperating better. I don't think the drive seek lights work on the front trays with them but I'm not concerned about that since this server sits in my cellar anyway and is rarely seen.)
FreeNAS 11.2 has been working happily for months now with this setup, until 2 days ago. I did the U7 update from U6 and the system never came back up. Actually, the USB thumb drive I use as the boot device for the system is still working fine. It attempt to boot FreeNAS 11.2U7 but throws some errors about the disk controller not responding to a command during boot and then says it can't locate any of my drive pools.
It appears the B120i controller failed, except the HP diagnostics report that it's "OK" and the "SuperCap" battery pack attached to it reports ok as well.
I went ahead and ordered an HP version of the LSI 9205 controller card, thinking I may need to disable the B120i and try it instead, plugged into a PCIe slot. But it'll be over a week before the card arrives in the mail, and it's still just a mystery to me why this problem only appeared with the U7 update? This server has been rebooted a number of times before and I've done other FreeNAS updates before without problems.
How to turn HP Smart array raid controller to HBA - Mode
Subscribe for more computer tips: https://www.youtube.com/c/HeikkiKoivisto/?sub_confirmation=1 Want to support channel? Create Aliexpress account here: https...
