storagefancontrol script to adjust fan speed based on hottest disk
pclausen
I was curious any anyone has been able to get this running on FreeNAS?
https://github.com/louwrentius/storagefancontrol
It checks the temp of all your hard drives using SMART and then adjust the chassis PWN fans so that the hottest drive is 40 degrees (value can be changed).
The author is running a Linux server and I wasn't use of FreeBSD has the support to control the PWM devices directly or of something else is needed to make it work.
