Stop Rsync or Cron Job
Rickinfl
Is it me or I'm blind and can't see it, but is there anyway to stop a Cron Job or , Rsync Job? without shutting down 8 VM's then rebooting an entire Freenas system.
Chris Moore
I am curious how you started the command and which command it is, but you can generally stop any running process with the kill command.
Rickinfl
In the GUI under Task. I have them scheduled and I needed to stop a running 1.
Chris Moore
In Unix and Unix-like operating systems, kill is a command used to send a signal to a process. By default, the message sent is the termination signal, which requests that the process exit.
Have you configured SSH so that you can connect from a remote terminal session?
https://www.ixsystems.com/documentation/freenas/11/services.html#ssh
You will want to do this from a terminal.
Here is a general guide: https://www.cyberciti.biz/faq/kill-process-in-linux-or-terminate-a-process-in-unix-or-linux-systems/
Chris Moore
Sorry, I don't think there is a GUI option that lets you kill a running process.
