no_connection
- Dec 15, 2013
Dell T20 with G3220 and 12GB RAM (4+8)
Four 4TB WD RED in Z2
FreeNAS-9.2.1.5-RELEASE-x64 (80c1d35)
I have run it a while and it seems to work well.
Depending on source I get 70MB+ write speed.
However it is slow when browsing directories. Once in cache it seems to browse the same directory just fine for a little while.
The problem is that it causes dropouts when streaming music or movies that is quite noticeable.
File browser also happily locks up while waiting.
CIFS share:
Taking one second to access a directory with 15 directories and one file in it.
Two seconds for 128 files.
Ten seconds for 354 files and 117 directories.
Eight seconds for 1190 files.
Forty seconds for 4296 directories.
Most of these takes a maximum of one sec on V7 with 6x 7200rpm drives in Z1 and 4GB RAM. (the NAS I'm replacing so I have the same data in two places to test with)
I know RED have worse access time and fewer spindles but transfers to and from the NAS at the same time does not seems to impact things too much and the other machines don't notice the hickups.
I noticed it being slow in 9.2.1.3 but with all the bugs and stuff I hoped it was temporary, so with most fixed in 9.2.1.5 I had high hopes.
I suppose that performance should not be this bad so something must be wrong somewhere.
Throwing more RAM at the problem might do something but I'm not sure that is the problem.
I will see if I can test with FTP or something if the access time is the same.
*edit* I created the dataset with atime set to inherit and didn't think about it at the time. Will change it once I stop transferring data to see if it helps.
CIFS share:
