jolanda7150
- Sep 16, 2022
I recently re-installed my TrueNAS server and re-configured it from scratch.
Now I'm in the process of copying my files from the old datasets to a new dataset structure.
While doing so the average speed is about 6,5MB/sec. This seems very slow.
When I try to access a SMB share in the meantime, even the process of navigating through folders is very slow.
Doing actions on files like renaming them is impossible. This is not a state that I want to accept any longer.
What would be the optimal speed to expect in my scenario?
In the past speed wasn't an issue but I never copied so many large files between datasets.
Where should I start to investigate how to improve speed?
Here are some facts about my setup. Please tell me if you need more.
- TrueNAS-13.0-U1.1
- 2 cores of Xeon E-2146G (16% utilization of those cores while copying)
- 32 GB RAM for the VM and 100% used due to caching.
- Installed as VM in Proxmox (Passthrough of HBA card flashed in IT mode)
- 1 pool with 1 vdev in RAIDZ2 (48% space used)
- 6x 6TB HDD drives (WD Red & Seagate IronWolf)
- Source and destination datasets are shared via SMB
- Both shares are mounted on a Debian stable PC. I copy files using Gnome's default file manager.
- Client is connected over GBit LAN (cable)
