setfacl Operation not supported
pawnaz
FreeNAS 9.3, I shared NFS dataset for ubuntu 12.04.4 LTS
On mounted NFS share I can't change permission using setfacl :
setfacl ... Operation not supported
Any ideas?
When I use qnap NFS share, there no problem with above task.
D
dlavigne
Guest
What type of dataset, what type of permissions, and is NFSv4 checked?
pawnaz
Dataset is type Unix (share type), NFS V4 was checked but I test with NFS V3,
share was mounted with/without acl options too....
I tested with and without maproot/mapall, changed permision type to windows, also I test security with and without sys. ;-) Full permutation.
Can you give me plain hint how I should configure FreeNas and Unix client to use setfacl with sucess, please, please.
D
dlavigne
Guest
Please post the exact setfacl command being performed. It is possible that you are trying to set posix ACL entries on an NFSv4 ACL.
