Set Docker container capabilities
RocketSam
Hello friends.
I've got a simple question about running custom Apps on TrueNAS Scale. What I need to achieve is to explicitly allow some capabilities for a container.
If I run docker container from a command line I will use
--cap-drop=ALL --cap-add=CHOWN --cap-add=SETUID --cap-add=SETGID --cap-add=DAC_OVERRIDE --cap-add=NET_RAW
Custom App wizard has corresponding section Capabilities, but I didn't find in what format should I declare it?
Thanks a lot!
I don't know for sure, but I would say that you can't use the first one and the rest would be specified only with what's on the right side of the equals sign.
Looks right to me... again, making assumptions, but I don't see how else it can work.
