Separate IP for Nextcloud
Betat0m
Hey all,
I'm currently trying to set up Nextcloud for external access via DDNS but I just need to give it a dedicated IP. I have an IP set aside already through the built in Ethernet port while everything else runs off a NIC.
I can't seem to be able to get assign the static IP from the built in Ethernet port to the jail when I install.
I can find result in scale but it doesn't offer up the same options as core.
Patrick M. Hausen
Are you trying to use the plugin? The plugins use NAT and as far as I know that cannot be changed. You can setup your own jail and configure as you prefer. There's a great script by @danb35 to help with the setup.
Betat0m
Yeah trying the plugin, tried through documentation as well where you can assign a static ip but I straight away get a vent issue. (Documentation)
save me chasing my tail, could you confirm this is the script? https://github.com/danb35/freenas-iocage-nextcloud
Patrick M. Hausen
Somehow your link is broken, but yes, this danb35 - extensive discussion here:
