SOLVED Seagate Exos 5E8 vs 7E8 8TB disks usage
ChrisRJ
12 drives is a pretty large pool. Hopefully not RAIDz1
Alecmascot
The 5E8 is SMR.....
Daisuke
The 5E8 is SMR.....
Great info, I had no idea. That answers my question, I need to get the 7E8 model.
I'm using RaidZ2 with a extra disk on the side (13 drives), in case of emergency replacement.
Samuel Tai
Samuel Tai
If it's not in that resource, you can assume the drive is non-SMR.
Redcoat
@TECK
"WD Red" should not be on a list of "supported disk models? Not SMR.", at least not without qualification.
May I suggest that you edit your post to prevent possibly misleading a reader?
