Scale Docker Gui build
kiwihuman
Hello Guys
Sorry i don't post alot any where so yea
So I'm just testing out the new Freenas Scale as i for one cant wait for Docker support in Freenas just playing around, but i think i have gotten myself stuck
Error: [EINVAL] chart_release_create.release_name: Does not match [a-z0-9]([-a-z0-9]*[a-z0-9])?
Whenever i go to make a Docker image I get this error above, i had a problem earlier with kubernetes not running but looked around here and got that going
umm oh
OS Version:TrueNAS-SCALE-20.12-ALPHA
Product:System Product Name
Model:Intel(R) Core(TM) i3-9100 CPU @ 3.60GHz
Memory:31 GiB
Any help would be great thank you so much
kiwihuman
update i can build Dockers in the Cli
just not the dock
and could someone please remove my 2nd post (posted the same thing 2 times, i'm not a smart man )
shadofall
Probably a bug in the initial alpha gui. I was able to deploy a container through the gui the other day with the nightlies. didn't quiet work like I expected but it did work. The not expected part could be due to not having fully wrapped my head around kube yet compared to docker. Or it maybe that it's very much a work work in progress and slot of it is more hard coded proof of concept than fleshed out yet.
kiwihuman
thanks you taking the time to replay shadofall, and thanks for the help, yea i guess so i mean it can make them in the cli and they work so looking like a GUI bug, have a wonderful week
i going to keep playing around with this alpha lol i don't expect much today, as i can't even post on a forum right today, without making two post
also thank you random mod that removed my second post =D
try not to include any uppercase, symbols or spaces in the Application name. Worked for me.
I had the same error as original poster and this solution worked. Uppercase characters seem to be the culprit. I was still able use a dash (-) in the name.
ornias
Yes this would work.
However I would highly advice against using dash in the name, which you would understand once you start looking at the service names :P
xtreamdev
This worked for me on version TrueNAS-SCALE-22.02.3
