Can you not create VM's with a Ryzen 7 3700X using a Gigabyte X570 gaming motherboard. VM is turned on in the BIOS and I can create VM's fine with Proxmox. I was thinking about moving to TrueNAS but if I can't create VM's then I can't do it. I am getting "Your CPU does not support KVM extensions." Is there a way around this issue?
