Reset/Restore Emby
bigtobu
I feel like I mess up the setting in Emby, and I would like to reset it. Reinstall the plugin will reset the setting?
SweetAndLow
Sweet'NASty
Unmount storage, remove plugin and install new plugin. That will make it like new again. Or you can just change your jail root dataset and install a new plugin while leaving the old one for reference.
Joshua Parker Ruehlig
Just uninstall and reinstall plugin will do? I can't destroy the dataset.
yes. don't destroy the jail dataset directly, uninstalling the plugin will do that for you.
