jordanthompson
- Mar 5, 2022
I have an old (10+ years) system that is beginning to fail. I want to replace it with more current (but not necessarily bleeding-edge) hardware. My budget is around $400 (not including memory that I can get from Dell credit.) I just want to replace the CPU, motherboard, memory, and CPU fan. Here are my criteria:
1) Either AMD or Intel is fine
2) Lower power usage (this is pretty important for me)
3) Needs to support TrueNAS and eventually SCALE, Plex server, a database server jail/VM and a web server jail/VM
4) Current system has:
1) 14 SATA drives (2 redundant for the OS, 4 for the Plex server, 8 for the main pool)
2) 32 GB DDR3 RAM
3) 8 cores
4) 4 port Ethernet card in a PCIE16 slot (I am only using three currently and it would be great to have all on the motherboard)
5) 16 port SATA card in a PCIE16 slot (it would be great to move as many of these to the motherboard)
6) The SATA card needs room for a separate fan assembly next to it
7) video card in a PCIE16 slot (it would be great to move this to the motherboard)
5) Dell does not have ECC memory so if that is a requirement it will cut into my budget.
My reasoning for moving as much to the motherboard is to reduce heat and increase airflow (maybe I'm wrong.)
I currently have 8 cores and don't want to go less (I don't think.)
I could go with more memory if that is suggested.
I have been looking at NewEgg and Amazon (and of course Dell for the memory). I am confused over the various combinations of CPUs and motherboards.
Any suggestions would be most appreciated.
2) 32 GB DDR3 RAM
3) 8 cores
