cfmedicus
- Sep 11, 2023
I had an app installed (photoprism) and used a dataset for the image storage. After removing the photoprism app completely I tried to remove the dataset, which is not used by anything else (eg samba service). Whenever I try to remove the dataset I‘ll get the error
[EBUSY] Failed to delete dataset: cannot destroy 'Data/photoprism': dataset is busy
I did (thanks to the newest update) a server restart, but that doesn‘t do it for me.
Any ideas how I could get rid of a unused dataset?
Best regards
cfmedicus
Best regards
cfmedicus
