Remotely test cpu
Robti
Hi just finishing running bad blocks and would like to test the cpu next, only problem is I remote into the server, so can anyone help on how to test the cpu ?
Thanks
Robti
Thanks I seen that looks like I need to get the server down to a monitor and use a live iso
I linked directly to a specific post (#7) within that thread on using the "jail method". No need to use an ISO or connect a monitor.
Robti
Thanks I thought that you recommended the live iso in post 8, sorry if I read it wrong
I, personally, prefer the live ISO method (to make it a pure heat/stress environment, without risk taking down the server while the pools are active and online.)
But you said you can only remote the server.
