tl;dr - What is the simplest (but still safe) way to set up and access a remote replication TrueNAS box in another city? And what steps do I need to ensure I've completed before I drive off?
I am doing my best to follow 3-2-1 rule (3 copies, 2 mediums, 1 remote). This question, is around 1 - remote.
I want to run a second TrueNAS box, set it up in another physical location (my parents house), and then set-up remote replication. This is the only role that this box will serve. And it will sit in another city completely, so it's important that I complete everything I need before I leave. Also there would be no static IP for either box.
Also, I am no security guru, and I am wondering 1) what is the safest way to configure this, and 2) what are the steps that I would need to complete before I drive home and try to connect and get this working?
I've read through this, but it's not exactly a tutorial is it, and I really don't want to create a security vulnerability when all I'm trying to do is protect my data. Or end up missing a step and driving home.
I think the part that I'm most worried about is
www.truenas.com
Configuring a New SSH Connection
Setting Up a Remote Replication Task
Provides instructions on adding a replication task with a remote system.
