I apologize for this question, I've done my research but I feel overwhelmed by the infos and I could really use your experience to point me in the right direction.
I need to build a storage + virtualization server for a small office, about 10TB of data and between 5 and 10 VMs. VMs will be both Windows and Linux and have to run a graphical interface.
No CPU/GPU intensive tasks. Our office handles mostly documents and images.
I want to use TrueNAS SCALE, I'm not comfortable with BSD.
Budget is around 4k € but I would like to contain the costs.
We have a rack cabinet in a closed, climatized room.
I'm not an hardware expert so I'd love to have some help!
What specs should I aim for?
Which IXsystems solution best suits my needs?
Which other servers work well with TrueNAS out of the box or with minimum replacements (like RAID Controller)
I'd like to overshoot the minimum requirements a bit and get something that can be upgraded if the need, hopefully, arises.
Thank you very much, I just need to be pointed in the right direction to continue my research ...then bother you again, eventually :P
