Raspberry Pi 4
Kport
Hey guys. Im planing to install freenas on a Rasberry pi 4. Will that work?
matuss
No.
Raspberry CPU architecture is not supported (Rpi has arm, but x86 is required).
Other than that it does not have enough RAM and your drives would have to be connected via USB.
If all you want to do is file sharing, just use the default OS Raspbian and set up a share on the network.
Assuming you want to do a Windows SMB share, here's an article from the MagPi on how to do that:
https://www.raspberrypi.org/magpi/samba-file-server/
Keep in mind that you won't have any of the feature set of FreeNAS with this approach with regards to redundancy, data integrity, availability, etc. The RPi can do many things but at the end of the day it is still a $35 computer.
HoneyBadger
actually does care
Administrator
Is there any option to Freenas that would work?
You might be able to compile ZFSonLinux on Raspbian for ARM. You still won't have ECC or SATA ports though.
This is a case of "hardware is not fit for purpose."
Kport
something else...
i tried to install Free nas on a old dell pc. it booted from the installation media but when i restarted the system and removed the installation media it wouldn't boot from the boot device.
it has a intel core 2 duo.
pro lamer
Some SBCs come already with ARMv8 which is/can be 64 bit. That makes me feel a bit optimistic for future of ZFS there. Future.
IIRC still no ECC and only some SATA to USB controller...
Sent from my phone
pro lamer
It might be worth a separate thread so you may attract people...
Sent from my phone
