Hi everyone, I purchased a used R740xd that I would like to use as a VM server (ESXi) and as a NAS using TrueNAS software. What I would like to do is use the front drives (x24 2.5" SAS 900GB 6G) for VMs and 4 internal drives (16TB 3.5" 7200 SATA) for the NAS. The server came with a PERC H730P raid card that does have HBA mode but I've heard conflicting as to if it should be used or not.
Currently I have ESXi running on the first 2 front bay drives (raid 1) and the rest of the front drives in a raid 10 config with a couple hot spares. The internal 16TB drivers are setup in a raid 10 config at the moment as well. All of this is via hardware raid using the PERC card. I would prefer all of this to be controlled via TrueNAS and ZFS... still using the idea of front bay drivers for VMs and internal for NAS.
My problem, is multi-fold...
#1. I don't know what I'm doing (obviously). Can someone please give me a jump start? I have been reading for about 3 weeks now and I'm still not where I need to be. I just want to make sure I do things in a good and reliable way right from the start. I don't have really "critical" data but it is important to me. I'm an astrophotographer in my spare time and the image files I have are large and there's lots of them. They take a long time to get and I just want to make sure they are protected as well as they can be. I started this whole thing with the idea of using raid to help protect my data... then I got sucked in because I'm a nerd and a software engineer but server hardware is not part of my skill-set... yet.
#2. If I need another HBA I really don't know what to get that will work for what I want to do and within my server. Any suggestions?
#3. I don't know if my idea of how things are going to be split is even a good one... meaning I will not be needing all the storage space on the front drives for a long time. Seems like it is not a good idea having drives plugged in and running if I don't actually need them yet. Can TrueNAS extend my storage if I just start with say 8 of the drives and later I need more storage?
#4. I would really like to hear your suggestions on how I should setup everything, from hardware to software, to HBA modules to boot drives, etc... I'm open to any advice you have.
Thanks for any info you want to share!
B
B
