Evening, I had a question about removing disks from a pool. I used the gui and went into storage > devices and went to the last drive in the pool. I then clicked remove and it has been sitting at 40% done for about two hours now, I assume it shouldn't take that long? I am trying to redo my pool setup and save my data so I got my data under 50% so I could pull some of the drives to make a new pool and then import the data over after, however I am stuck trying to remove drives from the pool right now.
Are you able to remove drives from a pool? I assumed it would just move the data off the disk being removed and then remove it, am I wrong?
