Python CPU Spikes
Dinez
Hello guys,
I've noticed that i get heavy CPU spikes that reach up to 60% of CPU usage.
If anybody could help out resolve this issue that would be great.
My System:
NZXT N7 Z390
Intel(R) Core(TM) i7-9700F CPU @ 3.00GHz
32 Gigs of ram
Kingston NV2 500GB M.2 NVMe
Powertech 1 Gig NIC (not using currently)
What, exactly, is there to resolve? The system does work, consuming CPU time.
Davvo
Are you asking us to identify where that python spawn is coming from without any context? That's a tad hard.
Dinez
Dont really have any context due to the fact that i dont know where its coming from or what the next steps is to dig further into.
Perhaps it's from the main middlewared process?
When you have htop open, press F5 to view a "tree" layout.
That is a good deal of CPU, though. Even for SCALE, surely?
On my Core system, with qBittorrent running in a jail 24/7, my CPU remains at 0 - 2%.
(My CPU graph looks like a patient flatlined on a hospital bed.)
anodos
Sambassador
That looks like the ZFS worker pool. Do you have some monitoring solution that's hitting our API endpoints? For example, I seem to recall a home assistant plugin that polls some rather expensive ZFS-related API endpoints.
Dinez
Deleted all snapshots and removed all periodic Snapshots tasks. If thats what you ment.
anodos
Sambassador
I'm talking about applications that poll our ZFS / storage related endpoints (for instance running apps or external). There are some that do this. That said, CPU utilization isn't necessarily surprising, there are periodic background tasks related to system / pool monitoring.
Dinez
Semi-Solution: If you have a ZFS pool that has been degraded you get those weird cpu spikes.
On my end a cable was loose on one of my hdd's and thats why i had those spikes.
After i put that cable back in everything works kinda fine now. The spikes are less frequent.
