Problems with server after powerout
Fafners
Hello all,
Before hand, big thanks for your time.
I unfortunately had a powerout and unfortunately since expirenced problems with my freenas server.
Problems:
Browseing folders takes time and sometimes times out via SMB.
Write to the raid takes time to initiate, but does succeed most of the time.
Read of files takes time to initiate and does not work with large files, like playing a movie. It will timeout. Small files can succeed.
WebGUI does not load for some of my devices (those who accessed it before crash).
My phone and work Laptop can access webgui.
I also recieve mails with erors of folders not existing and random restarts, which is strange.
Attempted:
Restart web gui services.
Two scrubs. One of them fixed 120K error the second none.
Smart scans that all returned positive results (attached).
I was runnning version 9.10 Stable. Then upgraded to 11.3-RELEASE-p9. Same issues.
Tried to install new bootdisk and fresh install of 11.3-RELEASE-p9. Same issues.
Im a little out of ideas. Any suggestions would be most welcome.
Motherboard:
Asus Rampage II Extreme
CPU make and model:
CPU: Intel(R) Core(TM) i7 CPU920 @ 2.67GHz (2670.06-MHz K8-class CPU)
RAM:
HyperX HX18C 4x8G
HyperX KHX1600C9D3T1K2 2x4G
real memory = 34359738368 (32768 MB)
avail memory = 33283596288 (31741 MB)
HDD Controller (HBA mode):
Promise SATA300 TX2plus 3Gb s
NIC:
Some Intel 1 gig card
OS:
FreeNAS: FreeBSD 11.3-RELEASE-p9 amd64
HDD, model and RAID configuration:
Boot drive: WD BLUE 300G 2,5"
Raid: raidz1-0
Raid disks: 7x WD RED 3 TB 3,5"
Mediasize: 3000592982016 (2.7T)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e3
descr: WDC WD30EFRX-68EUZN0
lunid: 50014ee20d79d1fe
ident: WD-WCC4N6JNV737
rotationrate: 5400
fwsectors: 63
fwheads: 16
Geom name: ada1
Providers:
1. Name: ada1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
lunid: 50014ee261fcacf1
ident: WD-WCC4N7PCNEKF
rotationrate: 5400
fwsectors: 63
fwheads: 16
Geom name: ada2
Providers:
1. Name: ada2
Mediasize: 320072933376 (298G)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e3
descr: WDC WD3200BPVT-26JJ5T0
lunid: 50014ee6587108fc
ident: WD-WX71AC269743
rotationrate: 5400
fwsectors: 63
fwheads: 16
Geom name: ada3
Providers:
1. Name: ada3
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
lunid: 50014ee2ba6b46c1
ident: WD-WCC4N1EZJTFZ
rotationrate: 5400
fwsectors: 63
fwheads: 16
Geom name: ada4
Providers:
1. Name: ada4
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
lunid: 50014ee262cf8da7
ident: WD-WCC4N4ALLD1L
rotationrate: 5400
fwsectors: 63
fwheads: 16
Geom name: ada5
Providers:
1. Name: ada5
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
lunid: 50014ee2652e9650
ident: WD-WCC4N1TLLXEX
rotationrate: 5400
fwsectors: 63
fwheads: 16
Geom name: ada6
Providers:
1. Name: ada6
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
lunid: 50014ee2b752b561
ident: WD-WCC4N7PCNK94
rotationrate: 5400
fwsectors: 63
fwheads: 16
Geom name: ada7
Providers:
1. Name: ada7
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
lunid: 50014ee20d79d929
ident: WD-WCC4N5NZVX5V
rotationrate: 5400
fwsectors: 63
fwheads: 16
  • smartscan ada0.txt
  • smartscan ada1.txt
  • smartscan ada2.txt
  • smartscan ada3.txt
  • smartscan ada4.txt
  • smartscan ada5.txt
  • smartscan ada6.txt
  • smartscan ada7.txt
