Hallo,
I installed Truenas SCALE and could already setup basic shares, but have problems with apps.
TrueNAS-SCALE-23.10.1
New catalog:
-Truechart
-Repository: https://github.com/truecharts
-Preffered Trains: stable
-Branch: main
Does not work, I get the message:
The standard repository "https://github.com/truenas/charts.git" does work and I alredy installed syncthing which is working. With this repository the connection is working
Thank you for your help
Christian
New catalog:
-Truechart
-Branch: main
Failed to validate catalog: [EFAULT] Failed to clone 'https://github.com/truecharts/' repository at '/var/run/middleware/ix-applications/validate_catalogs/github_com_truecharts__main' destination: [EFAULT] Failed to clone 'https://github.com/truecharts/' repository at '/var/run/middleware/ix-applications/validate_catalogs/github_com_truecharts__main' destination: Cloning into '/var/run/middleware/ix-applications/validate_catalogs/github_com_truecharts__main'... remote: Not Found fatal: repository 'https://github.com/truecharts/' not found
- I already set up Truenas a 2nd time
- Tried to set permissions of the switch so that I can get to https://github.com/truecharts: not sucessful
- I disconnected my switch and reset the router (activated dhcp) to get rid of all my ACL settings, as I could not solve the problems : not sucessful
- I used static IP 192.168.0.99, domain local (and 192.168.0.1), Public nameserver 1.1.1.1 and 8.8.8.8, Default Gateway 192.168.0.1
- curl
- I tried to check with "curl -ls https://google.com | head -n 1" if I get out via https: sucessful
- "curl -ls https://github.com | head -n 1" does respond a blank line with no output
Christian
