Yes, in the Apps UI, you can go to the "Manage Docker Images" tab, and then click the three-dot menus to remove specific ones. We'll be updating that section later to allow more proper bulk-delete / auto-pruning also.
If you are using truecharts apps they released their truetool with the ability to update apps and prune old images in one step. It only works for truecharts though.
That's the same we use in TrueTool, the TrueTool -p command is mostly meant as a easy addition for people that want to both run the updater, backup their apps and prune images daily (which should all three be done daily as well)
Hello, looking at the images I have, I see the previous versions that are still there, is it possible to delete them manually without affecting the service of the latest version?
Thank you
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
