SOLVED Offline uncorrectable sectors (changed -16)
gal onet
Hello.
I have read this thread because I have similar messages with TrueNAS Scale 23.10. I have executed the command above and got the output BUT I can not see any problem there!
The message is "Device: /dev/sdc [SAT], 7 Offline uncorrectable sectors.
2023-11-05 22:01:17 (America/Sao_Paulo)"
BUT it occurs with any one of my 06 SSD drives: sda, sbd, sdd, etc.. randomly when I first boot the device.
Running commands "sudo su -" and after "smartctl -x /dev/sde" this is the output:
root@truenas[~]# smartctl -x /dev/sdc
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.55-production+truenas] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     SSD
Serial Number:    2023030400077
Firmware Version: V0609B0
User Capacity:    2,048,408,248,320 bytes [2.04 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available
Device is:        Not in smartctl database 7.3/5319
ATA Version is:   ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Nov  7 16:20:37 2023 -03
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Unavailable
General SMART Values:
Offline data collection status:  (0x03) Offline data collection activity
                                        is in progress.
Self-test execution status:      ( 242) Self-test routine in progress...
                                        20% of test remaining.
data collection:                (  120) seconds.
capabilities:                    (0x11) SMART execute Offline immediate.
                                        No Auto Offline data collection support.
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        No Selective Self-test supported.
SMART capabilities:            (0x0002) Does not save SMART data before
                                        entering power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (  10) minutes.
SCT capabilities:              (0x0001) SCT Status supported.
SMART Attributes Data Structure revision number: 1
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     -O--CK   100   100   050    -    0
  5 Reallocated_Sector_Ct   -O--CK   100   100   050    -    0
  9 Power_On_Hours          -O--CK   100   100   050    -    228
 12 Power_Cycle_Count       -O--CK   100   100   050    -    26
160 Unknown_Attribute       -O--CK   100   100   050    -    0
161 Unknown_Attribute       PO--CK   100   100   050    -    100
163 Unknown_Attribute       -O--CK   100   100   050    -    47
164 Unknown_Attribute       -O--CK   100   100   050    -    661
165 Unknown_Attribute       -O--CK   100   100   050    -    6
166 Unknown_Attribute       -O--CK   100   100   050    -    2
167 Unknown_Attribute       -O--CK   100   100   050    -    3
168 Unknown_Attribute       -O--CK   100   100   050    -    5050
169 Unknown_Attribute       -O--CK   100   100   050    -    100
175 Program_Fail_Count_Chip -O--CK   100   100   050    -    0
176 Erase_Fail_Count_Chip   -O--CK   100   100   050    -    0
177 Wear_Leveling_Count     -O--CK   100   100   050    -    0
178 Used_Rsvd_Blk_Cnt_Chip  -O--CK   100   100   050    -    0
181 Program_Fail_Cnt_Total  -O--CK   100   100   050    -    0
182 Erase_Fail_Count_Total  -O--CK   100   100   050    -    0
192 Power-Off_Retract_Count -O--CK   100   100   050    -    4
194 Temperature_Celsius     -O---K   100   100   050    -    40
195 Hardware_ECC_Recovered  -O--CK   100   100   050    -    0
196 Reallocated_Event_Count -O--CK   100   100   050    -    0
197 Current_Pending_Sector  -O--CK   100   100   050    -    0
198 Offline_Uncorrectable   -O--CK   100   100   050    -    0
199 UDMA_CRC_Error_Count    -O--CK   100   100   050    -    0
232 Available_Reservd_Space -O--CK   100   100   050    -    100
241 Total_LBAs_Written      ----CK   100   100   050    -    50980
242 Total_LBAs_Read         ----CK   100   100   050    -    7338
245 Unknown_Attribute       -O--CK   100   100   050    -    27792
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x24       GPL     R/O     88  Current Device Internal Status Data log
0x25       GPL     R/O     32  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%       228         -
# 2  Short offline       Completed without error       00%       219         -
# 3  Short offline       Completed without error       00%       195         -
# 4  Short offline       Completed without error       00%       191         -
# 5  Short offline       Completed without error       00%       173         -
# 6  Short offline       Completed without error       00%       170         -
# 7  Short offline       Completed without error       00%       163         -
# 8  Short offline       Completed without error       00%       155         -
# 9  Short offline       Completed without error       00%       147         -
#10  Short offline       Completed without error       00%       136         -
#11  Short offline       Completed without error       00%       121         -
#12  Short offline       Completed without error       00%       107         -
#13  Short offline       Completed without error       00%        82         -
#14  Short offline       Completed without error       00%        75         -
#15  Short offline       Completed without error       00%        60         -
#16  Short offline       Completed without error       00%        37         -
#17  Short offline       Completed without error       00%        29         -
#18  Short offline       Completed without error       00%        24         -
#19  Short offline       Completed without error       00%        23         -
Selective Self-tests/Logging not supported
SCT Status Version:                  3
SCT Version (vendor specific):       0 (0x0000)
Device State:                        Active (0)
Current Temperature:                    40 Celsius
Power Cycle Min/Max Temperature:     40/40 Celsius
Lifetime    Min/Max Temperature:     23/40 Celsius
Specified Max Operating Temperature:   100 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Data Table command not supported
SCT Error Recovery Control command not supported
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              26  ---  Lifetime Power-On Resets
0x01  0x010  4             228  ---  Power-on Hours
0x01  0x018  6      3341088334  ---  Logical Sectors Written
0x01  0x020  6        25264443  ---  Number of Write Commands
0x01  0x028  6       480933938  ---  Logical Sectors Read
0x01  0x030  6         4845283  ---  Number of Read Commands
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
0x07  0x008  1               0  ---  Percentage Used Endurance Indicator
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  4            0  Command failed due to ICRC error
0x0002  4            0  R_ERR response for data FIS
0x0005  4            0  R_ERR response for non-data FIS
0x000a  4            2  Device-to-host register FISes sent due to a COMRESET
Could you help me read this output and understand it? Where are the errors? I can NOT see any, compared to previous post here!
Thanks.
[Mod Edit - Cleaned up code output, split to new thread]
gal onet
Hi. Thanks Mod for the new thread.
Could you remove the SOLVED tag for now?
Waiting for some ideas about this issue! As I wrote, I can NOT see where the problem is in this log!
bilson
I know this is an old thread but I went through something similar so I wanted to share my experience.
I have a pair of pretty well worn Micron 500DC 800GB I bought used on ebay. They are rated to 1.9PB and arrived with around 1PB writes on both. They have been working fine until one of them started triggering an almost daily alert of 2 offline uncorrectable sectors found. The value has not increased and the remapped sectors stays constant so it appears the drive is stable for now but it was annoying getting that email every day. And yes, micron firmware doesn't zero out the uncorrectable count when they are remapped. I found a recommendation to use the smartd.conf option of -U 198+ which is supposed to mark this as a problem only if the count increases. On truenas it seems you cannot manually make changes to the conf file (you do but it gets removed). So alternative was to go to Storage>disks section and edit, under smart options enter the U option with slightly different format: -v 198,increasing
Two days so far and no new alerts and emails. Hopefully it sticks.
To OP, you supplied smart data from sde but alert is for sdc
