nginx issue
alexbonazzi
I have TrueNAS Scale 22.12.3.3 and I reinstalled nginx 2.10.4_1.0.15 and put data and configuration files in a Host Folder (i.e. /mnt/disk1/disk2/nginx). when I start nginx is stuck in deploying and never come online. Anyone can suggest how to solve ?
If that's a reinstall, what was installed before?
How did you install it? TrueCharts? Launch Docker Image?
alexbonazzi
It stops deploying 1 month ago.
I tried reinstalling official end truecharts apps with same result.
Now I reinstalled witout using host path but nothing changes.
if I launch from pod shell nginx this is result.
"nginx: [emerg] open() "/etc/nginx/conf.d/include/resolvers.conf" failed (2: No such file or directory) in /etc/nginx/nginx.conf:52"
So it appears line 52 of the config file points to a file (/etc/nginx/conf.d/include/resolvers.conf) which doesn't exist...
I don't think I see that same error, but the way forward would seem to be to remove that line from that file.
Also, you mean nginx proxy manager, right?
alexbonazzi
I can't find any editor in pod how to have one ? and how to make this change permanent ?
I would start by creating an empty file in the expected location instead...
use
touch /etc/nginx/conf.d/include/resolvers.conf
Making it permanent is a whole different proposition as I haven't yet worked out why yours would be broken and mine isn't... perhaps that file is automatically created based on some DNS settings on the host.
alexbonazzi
use
nginx starts now thanks.
At login I got bad gateway now
alexbonazzi
use
I added a resolver directive and now I got this.
nginx: [emerg] cannot load certificate "/etc/letsencrypt/live/npm-3/fullchain.pem": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/npm-3/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
alexbonazzi
Solved certificate. Now at login I get bad gateway and took time many mintues to be active. Then when I add a host I get internal error.
