Nextcloud constant DEPLOYING
Dohuginn
After rebooting, Nextcloud is in continuous deployment. An error occurs when trying to view logs
Received 400 response code from '/api/v1/namespaces/ix-nextcloud/pods/nextcloud-b44cd658f-nr9w2/log?follow=true×tamps=true&timeoutSeconds=1800&container=nextcloud&tailLines=500'
Dohuginn
Application Name:nextcloudPod Name:nextcloud-postgres-6fb5dc686c-s5545Container Name:nextcloud-postgres
2023-04-09T05:39:18.554949139Z
PostgreSQL Database directory appears to contain a database; Skipping initialization
2023-04-09T05:39:18.555015174Z
2023-04-09 05:39:18.593 UTC [1] LOG: starting PostgreSQL 13.1 (Debian 13.1-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2023-04-09 05:39:18.593 UTC [1] LOG: listening on IPv4 address "0.0.0.0", port 5432
2023-04-09 05:39:18.593 UTC [1] LOG: listening on IPv6 address "::", port 5432
2023-04-09 05:39:18.615 UTC [1] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-04-09 05:39:18.639 UTC [26] LOG: database system was shut down at 2023-04-05 07:35:40 UTC
2023-04-09 05:39:18.640 UTC [26] LOG: invalid resource manager ID in primary checkpoint record
2023-04-09 05:39:18.640 UTC [26] PANIC: could not locate a valid checkpoint record
2023-04-09 05:39:18.650 UTC [1] LOG: startup process (PID 26) was terminated by signal 6: Aborted
2023-04-09 05:39:18.650 UTC [1] LOG: aborting startup due to startup process failure
2023-04-09 05:39:18.652 UTC [1] LOG: database system is shut down
Dohuginn
When trying to enter the shell
WARNING: Your user does not have sudo privileges so /usr/local/bin/k3s command will run
on your behalf. This might cause permission issues.
error: unable to upgrade connection: container not found ("nextcloud-postgres")
chenjingchun
我升级到TrueNAS-SCALE-22.12.2也遇到了相同的问题。所有容器都是DEPLOYING状态。
请问你解决了吗?
Received 400 response code from '/api/v1/namespaces/ix-transmission/pods/transmission-ix-chart-7f55d88bbd-j8d99/log?follow=true×tamps=true&timeoutSeconds=1800&container=ix-chart&tailLines=500'
chenjingchun
请问你解决了吗?
逛逛论坛还是有好处的,看了这个帖子
关闭Windows (SMB)共享再重启容器就解决了
pspenceri
I am not able to deploy my NEXTCLOUD (only gets 1/2). I have deleted and recreated pools and reinstalled multiple times...
2023-07-07 21:12:16
Startup probe failed: HTTP probe failed with statuscode: 403
2023-07-07 21:11:56
Container image "nextcloud:27.0.0" already present on machine
2023-07-07 21:11:26
Container nextcloud failed startup probe, will be restarted
2023-07-07 21:10:46
Startup probe failed: Get "http://172.16.0.32:80/status.php": dial tcp 172.16.0.32:80: connect: connection refused
2023-07-07 21:10:30
Created container nextcloud
2023-07-07 21:10:30
Started container nextcloud
2023-07-07 21:10:26
Successfully pulled image "nextcloud:27.0.0" in 19.339820616s
2023-07-07 21:10:07
Pulling image "nextcloud:27.0.0"
2023-07-07 21:09:48
Created container init-postgresdb
2023-07-07 21:09:48
Started container init-postgresdb
2023-07-07 21:09:48
Created container nextcloud-postgres
2023-07-07 21:09:48
Started container nextcloud-postgres
2023-07-07 21:09:47
Successfully pulled image "postgres:13.1" in 10.463261281s
2023-07-07 21:09:44
Successfully pulled image "postgres:13.1" in 8.195539377s
2023-07-07 21:09:36
Add eth0 [172.16.0.32/16] from ix-net
2023-07-07 21:09:36
Pulling image "postgres:13.1"
2023-07-07 21:09:36
Add eth0 [172.16.0.33/16] from ix-net
2023-07-07 21:09:36
2023-07-07 21:09:35
Scaled up replica set nextcloud-postgres-7784cfc67 to 1
2023-07-07 21:09:35
Scaled up replica set nextcloud-7f48b64459 to 1
2023-07-07 21:09:35
Created pod: nextcloud-postgres-7784cfc67-mgcf2
2023-07-07 21:09:35
Successfully assigned ix-nextcloud/nextcloud-postgres-7784cfc67-mgcf2 to ix-truenas
2023-07-07 21:09:35
Created pod: nextcloud-7f48b64459-j97vp
2023-07-07 21:09:35
Successfully assigned ix-nextcloud/nextcloud-7f48b64459-j97vp to ix-truenas
Dohuginn
Warning Unhealthy 70s (x18 over 3m36s) kubelet Readiness probe failed: HTTP probe failed with statuscode: 503
Is there any solution to this problem?
