I'm currently thinking of building a new NAS based on TrueNAS to replace all my Synology and have better flexibility and possibility to upgrade.
I made a lot of research but I struggling to find a good compromise for motherboard/CPU/RAM that supports ECC (25 To of data so I think it's better to avoid some loss 'cause of corruption even with backups)
My main usage is only to store and access data by a Plex Server hosted on an ESXi so I don't need that much power and I would like to limit my expense.
The only things I know :
Case will be Fractal Design Node 804 because I already have one and it's perfect for my need but because of this I'm nnot available to have all size of motherboard.
Number of SATA port is not an issue because I'll use a LSI 9211-8i to connect them.
Have you got any advice ?
Thanks for your help
