I just installed TrueNAS 12.0-U5 as VM on my Proxmox server.
The installation was pretty simple, but after the first reboot I got an IP "http://0.0.0.0"
So, on the console I type 1 to go to the network options. I follow the steps and provided an static IP 45.62.203.199 and netmask 255.255.255.192 but after that process I'm not able to go to the Browser and open the UI using that IP.
Is there any config file that I can check? I'm not sure if the system added a gateway or not.
If I type 9 to access the shell and run "netstat -rn" I got:
45.62.203.192/26 link#1 U em0
45.62.203.199 link#1 UHS lo0
127.0.0.1 lo0 UHS lo0
Thanks.
Thanks.
