SOLVED Network Error 0x8007003B - Problems transferring files to FreeNAS
error500
When ever I try to transfer a file from my PC to my FreeNAS box, I'll get this error. Usually with one or two retry's the transfer will work but on bigger files I can't finish the transfer at all.
I've done a full work days worth of googling this error and haven't found anything that has worked for me.
-Things I've Tried-
Changing Max SMB Protocol
Changing MTU size
Disabling Windows Search Service
New Installation of FreeNAS
System Information
Hostname freenas.local Edit
Build FreeNAS-11.1-U5
Platform Intel(R) Celeron(R) CPU J3160 @ 1.60GHz
Memory 7820MB
System Time Mon, 25 Jun 2018 13:35:15 -0700
Uptime 1:35PM up 1 day, 4:21, 0 users
Load Average 0.51, 0.39, 0.34
Chris Moore
Memory 7820MB
While I appreciate your attempt, this is only a tiny sliver of the information that is needed about your hardware. I really am not trying to be difficult, but we do need the information about the hardware you are trying to run FreeNAS on, as is explained here:
Updated Forum Rules 4/11/17
https://forums.freenas.org/index.php?threads/updated-forum-rules-4-11-17.45124/
Particularly:
  • motherboard make and model
  • CPU make and model
  • RAM quantity
  • hard drives, quantity, model numbers, and RAID configuration
  • hard disk controllers
  • network cards
It might even be helpful to know about your computer.
kdragon75
Have you tried anything from this thread? This sounds like a Windows issue.
error500
I did try that as well, but after re-installing a fresh FreeNAS I left the monitor connected and noticed I was getting these errors
re0 watchdog timeout
and then this morning I got a kernel log with this
re0: watchdog timeout
re0: link state changed to DOWN
re0: link state changed to UP
...and after some searching it seems this is directly related to my issue. Turns out I have a crappy Realtek embedded NIC. I'm not entirely sure why it decided to start giving me trouble out of nowhere but all my research says I need an Intel NIC which will be delivered tomorrow. I will report results once it arrives.
Jailer
Not strong, but bad
Chris Moore
If you would have told us what your hardware was, we could have told you what the problem was, but if you prefer to dig for it on your own...
error500
Intel NIC arrived and viola all my problems are solved. My speeds are awesome finally actually getting gigabit transfer speeds between my PC and NAS.
Chris Moore
If you will give a rundown of the hardware you have in your system, we can point out other things that might be problems waiting to happen.
error500
Particularly:
  • RAM quantity
  • network cards
I'm sorry, I have no idea how I managed to miss all three of your posts.
Asrock J3160DC
8GB RAM
4 x Seagate Barracuda's 1TB - RAIDZ
Onboard SATA
Intel Gigabit Pro CT Network Adapter
DrKK
FreeNAS Generalissimo
Well, you've found the nearly ideal board to NOT use with FreeNAS. I'll give you credit for that. :)
Chris Moore
You might want to review the hardware guide that was developed to help with selecting good hardware. That way you can pick a better system next time. Also, don't be afraid to ask for advice. Between the regulars here, it is probably over a hundred years of combined experience. Not to say anyone is getting old...
Hardware Requirements
http://www.freenas.org/hardware-requirements/
FreeNAS® Quick Hardware Guide
https://forums.freenas.org/index.php?resources/freenas®-quick-hardware-guide.7/
Hardware Recommendations Guide Rev 1e) 2017-05-06
https://forums.freenas.org/index.php?resources/hardware-recommendations-guide.12/
Slideshow explaining VDev, zpool, ZIL and L2ARC
https://forums.freenas.org/index.ph...ning-vdev-zpool-zil-and-l2arc-for-noobs.7775/
Terminology and Abbreviations Primer
https://forums.freenas.org/index.php?threads/terminology-and-abbreviations-primer.28174/
error500
Really? This thing runs great as my Minecraft Server, File Server, and I watch movie's off it from Kodi on a Fire Box (not the stick) in the living room.
I get the "preferred" hardware is of the higher grade but I've hit all the criteria for my needs.
Small FreeNAS for a Few Users
  • Multicore 64-bit processor
  • 8 GB or larger boot drive
  • 8 GB RAM
  • One Ethernet network port
  • At least one hard disk for storage
error500
For some reason when ever you comment on here I don't get a notification, I got an email that DrKK replied but nothing about your reply
Chris Moore
Hey if it does what you need that's all that matters, but whenever you want to build a bigger system, better system, later on I thought you might want to look at the guides. there you go.
Chris Moore
Strange. I don't know why.
