Need to reinstall TrueNAS Scale because of bad boot drive - what do I need to know
scotrod
Hi. Sorry if this has been asked countless times and please redirect me if there is such guide already.
I need to reinstall (((OR migrate?))) my TrueNAS Scale installation because of bad boot drive. I got the following error:
Device: /dev/sdd [SAT], 1 Currently unreadable (pending) sectors.​
2023-04-25 01:40:40 (Europe/Sofia)
sdd is my 120gb ssd boot drive - a single one, so no RAID.
The way i see it, I can either:
- save my config (already did that), plug another 120GB ssd > dublicate my boot drive/create RAIDZ1
- remove the bad drive > add another drive to its place > install TrueNAS Scale > import my config > import my pools
Is there anything important I should know? I'm using this software for ~2 months – I have no mission-critical info on it, but still wouldn't want to start from scratch as my Blu-ray collection is already on it.
Thanks!
scotrod
I have a task scheduled to run LONG S.M.A.R.T. test every Sunday night, and here is what I get from running smartctl -a /dev/sdsd:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build)
Device Model: ADATA SU700
Serial Number: 2H2420086505
LU WWN Device Id: 5 707c18 100521a25
Firmware Version: L170203b
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Apr 25 17:33:20 2023 EEST
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
data collection: ( 33) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
Conveyance self-test routine
SCT capabilities: (0x0039) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 0
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 23398
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 511
167 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 0
168 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 0
169 Unknown_Attribute 0x0013 100 100 010 Pre-fail Always - 0
173 Unknown_Attribute 0x0012 200 200 000 Old_age Always - 8613265636
175 Program_Fail_Count_Chip 0x0013 100 100 010 Pre-fail Always - 0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033 100 100 020 Pre-fail Always - 256
192 Power-Off_Retract_Count 0x0012 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 066 066 030 Old_age Always - 34 (Min/Max 27/40)
231 Unknown_SSD_Attribute 0x0033 093 093 005 Pre-fail Always - 7
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 47441613952
234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 23748241424384
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 32438661200
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 14181316402
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Etorix
Plan 2:
Done!
scotrod
Plan 2:
Done!
I'm taking that exporting and importing the config is idiot-proof and will even recognize my pools/import all of my settings? Meaning I will not have to do any additional settings, like import SSH keys and so on?
SSH keys is the one thing not captured in the config, so manually take that and put it back after.
scotrod
Sweet, thanks. Will confirm here if everything went smoothly - just exporting and importing the config looks too good to be true.
You can find hundreds of "it went really well" posts on the forum, so hopefully this will now add to that list.
scotrod
Yeah, it went really well. A lot of thanks to the developers who implemented such an easy process!
