I have two similar NAS set ups. One is WD reds in raid 1 other is Toshiba 5TB in raid 1.
One of my toshibas runs hotter than the other. I swapped their position in the case and the same drive runs hotter, so its not a air flow issue its something about that drive that makes it run hotter. Maybe they forgot to lube the spindle
43c seems a bit warm and will cause that drive to fail sooner. Should I send this back under warranty before it fails? Is that enough of a difference for a return?
WD drives both run at 28c
Toshiba - one runs at 36c other at 43c
